Smog Fail - need advice
Posted: Wed Sep 29, 2010 4:52 pm
by Steve Towers
My 2000 Vette failed smog due to code 0113 (Intake Air Temperature). I replaced the sensor but I'm still getting the code. Any thoughts?
Re: Smog Fail - need advice
Posted: Wed Sep 29, 2010 5:31 pm
by Eric Clements
If its not the sensor, wiring/connectors to the ecu. And did you clear the code after replacing the sensor? The ecu will store old codes for quite a while...then after having codes cleared it take time for the ecu to run tests to be ready for smog.
Posted: Wed Sep 29, 2010 7:40 pm
by Steve Towers
Yea, I did clear the code. I'm going to clear it again tomorrow and take the car for a 30 mile ride. It's interesting that changing the sensor did make the "active handling warming up" go away from the DIC (supposedly that message appears if the sensor thinks the intake air is too cold) but didn't affect the code.
Posted: Thu Sep 30, 2010 3:23 pm
by Steve Towers
Turns out Eric was correct. There was a faulty wire inside the connector to the sensor. New connector spliced into the existing wiring seems to have solved the problem. I'll give it a few days and if no code issues, I'll retry the smog deal.
How it came to pass that the air intake temp would affect the active handling is certainly puzzling.
Posted: Fri Oct 01, 2010 1:17 pm
by Steve Towers
Passed smog today. Whew!
Posted: Fri Oct 01, 2010 1:42 pm
by Jayson Woodruff
Short might pull down a buss or something.
Or maybe the sensor read off scale low (i.e., freaking cold), and told the system to be on extra lookout for ice
Steve Towers wrote:How it came to pass that the air intake temp would affect the active handling is certainly puzzling.
Posted: Fri Oct 01, 2010 6:19 pm
by Steve Towers
Or maybe the sensor read off scale low (i.e., freaking cold), and told the system to be on extra lookout for ice .
Apparently that is exactly what occured. Before replacing the connector, the intake temp read -38F (on an 80 degree day).
