				5 Spoke Centerlines
				Posted: Sun Apr 17, 2011 6:25 pm
				by Ryan Korbian
				Re: 5 Spoke Centerlines
				Posted: Mon Apr 18, 2011 9:09 am
				by Ryan Korbian
				Rims weight 13 lbs
				Posted: Sun Apr 24, 2011 1:32 pm
				by Ryan Korbian
				$420?
				Posted: Sun Apr 24, 2011 4:55 pm
				You didn't answer my last email from a few days ago?
				Posted: Sun Apr 24, 2011 6:00 pm
				by Bill Martin
				What's the backspace?  Measure from a long straight edge behind the wheel to the hub-mounting surface.
				Posted: Mon Apr 25, 2011 11:57 pm
				by Ryan Korbian
				Hey Mako, I thought I did ill check again
				Posted: Fri Apr 29, 2011 6:41 pm
				by Ryan Korbian
				resent email did you get it?
				by Ryan Korbian
				Back space is ~4 inches with my crappy tape measure
				Posted: Sat Apr 30, 2011 3:22 pm
				by Ryan Korbian
				Outdo your competition with the look and performance of the Legend Series wheels. This is a ROTARY FORGED billet aluminum wheel manufactured by welding the center section into an outer rim.
Manufactured in the USA.
Centerline LEGEND SERIES-TELSTAR
Technical Specifications
2-piece, Rotary Forged Wheel -- the center section is welded into an outer rim enabling you to customize the rearspace & width
Manufactured to precise tolerances using highest quality T-6061 Billet Aluminum
1625 lb. load rating per wheel w/ 32" max tire diameter
__________________
				Posted: Wed Jun 15, 2011 9:16 am
				by Ryan Korbian
				Need to get these out of the garage, anyone want them for $300?
