Hot R Comp Rubber Collection
Posted: Tue May 27, 2008 9:06 pm
by Chad Stubblefield
Im kind of new to R comps (Hoosier A6) so have a heart.
I have been collecting a lot of abandoned rubber on my tires while on course and its been fusing with my tires.
It has actually filled in one of the groove lines completly.
I think this would effect the tire performance, am I right?
So do I use my first lap just to scrubb this off?
Do I need to worry about this at all?
thanks
Re: Hot R Comp Rubber Collection
Posted: Wed May 28, 2008 7:01 am
by Max Hayter
Jeff Kiesel uses a tire scrubber - it's like a metal loofah!
Posted: Wed May 28, 2008 7:52 am
by George Schilling
Max Hayter wrote:Jeff Kiesel uses a tire scrubber - it's like a metal loofah!
Damn, is that what that was. He had me using it all wrong. :lol:
The tire scrapers are available at C2 Motorsports. They're inexpensive and work great. Give Steve a call. Their banner is on the Solo2.com site.
Posted: Wed May 28, 2008 9:44 am
by Jason Isley BS RX8
I use a small hand held torch and a putty knife to remove build-up, works great.
Posted: Wed May 28, 2008 10:15 am
Jeff and Nicole have been wondering where THEIR rubber has gone ... please get in touch with them so that you can return it.
Most people complain about going through their R's. You should be happy! :D
Posted: Wed May 28, 2008 10:19 am
these Hoosiers have been holding up nicely 40+ runs. But Maybe Im not going fast enough to kill em.
Jeff is more than welcomed to come and peel his tires off mine.
Posted: Wed May 28, 2008 7:31 pm
by Chuck Fowler
Chad Stubblefield wrote:these Hoosiers have been holding up nicely 40+ runs. But Maybe Im not going fast enough to kill em.
ooh ooh let me try :mrgreen:
Posted: Tue Jun 03, 2008 4:54 pm
by Bill Martin
Jason Isley BS RX8 wrote:I use a small hand held torch and a putty knife to remove build-up, works great.
Jason, given that race tire life is often measured in heat cycles rather than calendar age, are you concerned what the flame contact might be doing to the good rubber? I realize it's brief, and mostly directed to the pickup, but I'm sure it would seriously blister your skin...might it not cause at least surface damage to the rubber?
I grind off the pickup with a 5" disc grinder fitted with a stiff wire brush cup. And try to limit the brush contact to the pickup. But I'm sure the result isn't as good looking as you can get with a torch and spatula.
Posted: Tue Jun 03, 2008 5:05 pm
Bill Martin wrote: Jason, given that race tire life is often measured in heat cycles rather than calendar age, are you concerned what the flame contact might be doing to the good rubber? I realize it's brief, and mostly directed to the pickup, but I'm sure it would seriously blister your skin...might it not cause at least surface damage to the rubber?
If I was worried about "heat cycles" I would not drive to events on my tires either. :lol:
Just like your method, I only heat up the area with the rubber pick-up, which is not the whole tire. :thumbup:
Posted: Tue Jun 03, 2008 5:44 pm
by Giovanni Jaramillo
George Schilling wrote:Their banner is on the Solo2.com site.
And also the sponsors are at the bottom of all forum pages.
Posted: Tue Jun 03, 2008 5:48 pm
But they are not hot links, which they probably should be.
Posted: Wed Jun 04, 2008 2:17 pm
by Steve Coe
Thanks for the plug George! I'll bring some up at the next event. Look for a red STS2 Miata #935
Posted: Wed Jun 04, 2008 5:03 pm
Is he using the Rocks Off device for this?
