Replacement Brake Hoses
Posted: Fri Jul 15, 2011 1:52 pm
by Steve Towers
I'm going to replace the brake hoses on the Vette and the OEM hoses are discontinued. Any brand preferences from your experience?
Re: Replacement Brake Hoses
Posted: Fri Jul 15, 2011 2:47 pm
by KJ Christopher
What year is your vette?
Posted: Fri Jul 15, 2011 3:00 pm
by Arthur Grant
OEM are rubber, why wouldn't you upgrade to steel braided? Much better peddle feel?
Posted: Fri Jul 15, 2011 3:17 pm
by Craig Naylor
Arthur Grant wrote:OEM are rubber, why wouldn't you upgrade to steel braided? Much better peddle feel?
If he is in a stock class, and his car is 1992 or newer... because it would be against the rules.
Posted: Fri Jul 15, 2011 3:51 pm
by Steve Towers
My car is a 2000. Mr. Naylor has it correct.
Posted: Fri Jul 15, 2011 10:53 pm
by Arthur Grant
Steve Towers wrote:What year is your vette?
Bummer dude.
Posted: Sat Jul 16, 2011 11:05 am
by Bob Pl
Keep in mind that GM has issued a tsb re: ss brake lines causing issues with wheel speed sensors, some have problems some don't may be MY specific.
Posted: Sat Jul 16, 2011 6:01 pm
by Steve Towers
Can't do SS in stock anyway. When the shop I took the car to called the local GM dealer for hoses they were told the oem hoses are "a discontinued item for all C5's". Look like aftermarket rubber is the only answer.
Posted: Tue Jul 19, 2011 6:12 pm
Bob Pl wrote:Keep in mind that GM has issued a tsb re: ss brake lines causing issues with wheel speed sensors, some have problems some don't may be MY specific.
I'm trying to imagine how the hose material would affect the wheel speed sensor.
Posted: Tue Jul 19, 2011 6:38 pm
by Bob Pl
Bob Beamesderfer wrote:Bob Pl wrote:Keep in mind that GM has issued a tsb re: ss brake lines causing issues with wheel speed sensors, some have problems some don't may be MY specific.
Link to tsb
http://www.identifix.com/tsbfiles/108000/107740.pdf" onclick="window.open(this.href);return false;
Electronic interference? Static buildup? Aliens?
TSB's are usually short on the why an engineering/manufacturing issue happened. Just this is what you do to fix it for the field tech.
Good to have a post from you dude, been a long time.
Posted: Wed Jul 20, 2011 7:58 am
by Craig Naylor
I like how the TSB includes the 2012 and 2013 model years.
Posted: Wed Jul 20, 2011 9:38 am
by Doug Kott
I'm running SS lines on my '05 Vette, with no issues/glitches so far. I realize they're prohibited in Stock classes, but if the class allows, I consider them a good upgrade. They take a little mush out of the initial application, and really yield a harder pedal when you stand on the brakes.
I had some issues with the fittings on Goodridge lines--couldn't even begin to hand-thread them for the first turn or so where they meet the hard line--so I took them back and swapped them for StopTechs, which easily threaded right up.
