ES/SK2 Miata NA wheels
Posted: Tue Dec 06, 2011 11:11 pm
Are 15 inch wheels legal for ES / SK2 NA Miatas since they were available on the M models?
Only if your Miata is an M Model.Jeremy Cottrell wrote:Are 15 inch wheels legal for ES / SK2 NA Miatas since they were available on the M models?
And THAT's only for 95-96. And as an "M", they would be either BBS (95) or Enkei (96). In 97, the "M" is a 6-spoke vs. 5-spoke and, a new "Special Touring Option" package was introduced in which the wheel was 15" Enkei.Leonard Cachola wrote:Only if your Miata is an M Model.Jeremy Cottrell wrote:Are 15 inch wheels legal for ES / SK2 NA Miatas since they were available on the M models?
Do not forget, they must also be the same offset +/- ~5mmJeff Stuart wrote:Though to be clear, you can use any wheels you'd like that are the same size (diameter and width) as the stock wheels for your model. You can also use any tires you'd like that you are able to fit onto those wheels.
Added a couple details.Jeff Stuart wrote:Though to be clear, you can use any Metal wheels you'd like that are the same size (diameter and width) as the stock wheels for your model. You can also use any DOT tires you'd like that you are able to fit onto those wheels.
Eric, did you choose pink as a highlighter because Max and I drive Miatas? Why don't you just come out and say it. :heyes:Eric Clements wrote:Added a couple details.Jeff Stuart wrote:Though to be clear, you can use any Metal wheels you'd like that are the same size (diameter and width) as the stock wheels for your model. You can also use any DOT tires you'd like that you are able to fit onto those wheels.
Ed Holley wrote:Eric, did you choose pink as a highlighter because Max and I drive Miatas? Why don't you just come out and say it. :heyes:Eric Clements wrote:Added a couple details.Jeff Stuart wrote:Though to be clear, you can use any Metal wheels you'd like that are the same size (diameter and width) as the stock wheels for your model. You can also use any DOT tires you'd like that you are able to fit onto those wheels.
I have a set of 15" Miata wheels, and a set of 14" Revolutions (one of the lightest 14x5.5" wheels available) for sale if your looking for a second set of rims for your car.Jeremy Cottrell wrote:Are 15 inch wheels legal for ES / SK2 NA Miatas since they were available on the M models?
