$40 rebate on a set of Star Specs at TireRack
Posted: Thu Mar 01, 2012 9:42 am
by Davin Swanson
TireRack has a $40 mail-in rebate available when you buy a set of Star Specs. Good for the month of March. Great for people considering the new RT classes at the SD national event and the El Toro ProSolo! Here's a link:
http://www.tirerack.com/specialoffers/d ... omoID=D214" onclick="window.open(this.href);return false;
Watch out, fellow SK2'ers, those factory Bridgestones are going to the dump.
Re: $40 rebate on a set of Star Specs at TireRack
Posted: Thu Mar 01, 2012 9:51 am
by Jeff Stuart
You've been on OEM tires this whole time?! Wow, you're going to like those Star Specs
Posted: Thu Mar 01, 2012 10:20 am
by Tin Bui
And I just bought my tires two days ago.
Posted: Thu Mar 01, 2012 11:05 am
by Davin Swanson
Yeah, I figured I'd shred the OEMs while I figured out what I was doing. I still don't know what I'm doing, but that's beside the point... the OEM tires are trashed. With the factory alignment only the outer third was wearing. There's plenty of tread left on the inside!
Posted: Thu Mar 01, 2012 12:08 pm
by Jeff Stuart
No amount of alignment with an SK2 car will change that
My front camber maxes out at about 1.4°. If I could, I would run >4°... Maybe then I would get somewhat even wear.
Posted: Thu Mar 01, 2012 1:23 pm
I'd flip them and use them for El Toro practices, then use the Star Specs for the events. You'd have to find a used set of wheels to do that, though.
