Recommendation for Head Shaving and ...
Posted: Thu May 31, 2012 4:12 pm
... cam shaft install, for our SCCA STL Miata.
I'm thinking Shawn Church will only do the tune but not these other items?
Re: Recommendation for Head Shaving and ...
Posted: Thu May 31, 2012 4:41 pm
by Marshall Grice
john edwards.
Posted: Thu May 31, 2012 4:43 pm
by George Schilling
The more hair I lose, the more I consider it. If I did, I was thinking I'd do it myself.
Max might have some suggestions.
I concur with Marshall.
Posted: Thu May 31, 2012 5:40 pm
USMC
Posted: Thu May 31, 2012 5:45 pm
by KJ Christopher
http://www.headblade.com/" onclick="window.open(this.href);return false; was pretty popular when I shaved my noggin. However, I just used shaving oil and a Mach 3.
Posted: Thu May 31, 2012 6:36 pm
by Mark DeShon
Agreed. I think Max is the expert in this department.
Mark D.
Posted: Thu May 31, 2012 9:01 pm
by Max Hayter
Norelco electric body shaver - use directly on your head, and any other parts that need a trim!
Posted: Thu May 31, 2012 9:59 pm
I emailed John. Anyone have a phone number
Posted: Thu May 31, 2012 10:11 pm
by KJ Christopher
Mako Koiwai wrote:I emailed John. Anyone have a phone number
http://www.engine-machining.com/" onclick="window.open(this.href);return false;
(949) 631-6376
Posted: Fri Jun 01, 2012 1:16 am
by John Fendel
I also concur with Marshall.
Posted: Fri Jun 01, 2012 8:57 am
by Vincent Wong
Max Hayter wrote:Norelco electric body shaver - use directly on your head, and any other parts that need a trim!
Posted: Fri Jun 01, 2012 9:40 am
by Jason Isley BS RX8
Mako Koiwai wrote:... cam shaft install, for our SCCA STL Miata.
+1 for John, we had him do one of our Toyota heads.
While you are at it don't for get to port the intake/exhaust and work the valves (as allowed).
Posted: Fri Jun 01, 2012 10:26 am
thanks ...
Found a plastic shop that is cutting the rear window polycarbonate to a pattern that I carefully made ... for the new light weight, 10 lb hardtop. If that works out OK, might do the front window also ... since we need to have it replaced anyway. Big crack. Going to study other Miata's this weekend to see how they do their front wind screens
Posted: Fri Jun 01, 2012 10:39 am
by Toby Larsson
I wouldn't do the windshield in lexan, by the time it's all installed in the correct thickness and with the required straps it's a minimal weight saving. It will also scratch easy, it makes sense for the thinner material in the rear.
Posted: Fri Jun 01, 2012 10:52 am
Toby Larsson wrote:I wouldn't do the windshield in lexan, by the time it's all installed in the correct thickness and with the required straps it's a minimal weight saving. It will also scratch easy, it makes sense for the thinner material in the rear.
Agree. It will also end up costing more by the time you are done.
Posted: Fri Jun 01, 2012 11:00 am
I was thinking that also ... I guess Toby should know ... having done it.
I was wondering about temporarily disabling the wind shield wiper, since on the Miata one can easily accidentally engage them.
Interesting, NASA wants 3/16th for all Lexan, all around as opposed to our 1/4, 1/16 and 1/8th
Posted: Fri Jun 01, 2012 11:05 am
That is a bummer - not that the rules typically line up anyway.
Posted: Fri Jun 01, 2012 11:24 am
They're going for convenience, we're going for an extra light over all performance window package
SCCA: 1/4 + 1/16 + 1/16 + 1/8th = 8/16th = 1/2"
NASA: 4X 3/16th = 12/16th = 3/4" worth of Lexan
Posted: Fri Jun 01, 2012 12:25 pm
Mako Koiwai wrote:They're going for convenience, we're going for an extra light over all performance window package
Where are you pulling the 1/16" SCCA spec from? Its 1/4" front, 1/8" all others - for Club Racing.
Posted: Fri Jun 01, 2012 1:01 pm
by Toby Larsson
If you're prepping for STL just move the wiper function to a flip switch on the dash board. No need to keep any of the factory switches, gauges or any other part of the electrical system.
Posted: Fri Jun 01, 2012 9:14 pm
Assassins Everywhere ... can't believe anyone!
