ProFinale Pressure Swap
Posted: Tue Aug 21, 2012 2:02 pm
I know we still don't know who runs when, but is anyone going to the Pro Finale interested in going quid pro quo on tire pressure duty?
Re: ProFinale Pressure Swap
Posted: Tue Aug 21, 2012 2:17 pm
by Max Hayter
Kurt Rahn wrote:I know we still don't know who runs when, but is anyone going to the Pro Finale interested in going quid pro quo on tire pressure duty?
I don't need any help, but will certainly help you out if I'm free.
Posted: Tue Aug 21, 2012 5:56 pm
by Tom Berry
+1
Posted: Tue Aug 21, 2012 7:25 pm
Thank you, mah peeps! I'll circle back after we find out the run times.
Posted: Wed Aug 22, 2012 8:03 am
by Marshall Grice
Kurt Rahn wrote:Thank you, mah peeps! I'll circle back after we find out the run times.
i'd almost guarantee that you're in the first heat.
Posted: Wed Aug 22, 2012 8:50 am
How come?
Posted: Wed Aug 22, 2012 9:00 am
by Craig Naylor
Traditionally at Pro's stock classes run first (low hp before high hp), then the start mixing in the Street Tire, moving on to SP, Mod, and Prep. The bigger your class, the more likely you'll fall into the traditional run order, the smaller, the more likely your fill in fodder to make even sized groups.
So low hp, stock, street tire, good sized class... good odds being first.
Posted: Wed Aug 22, 2012 9:40 am
Craig Naylor wrote:Traditionally at Pro's stock classes run first (low hp before high hp), then the start mixing in the Street Tire, moving on to SP, Mod, and Prep. The bigger your class, the more likely you'll fall into the traditional run order, the smaller, the more likely your fill in fodder to make even sized groups.
Got it. Good to know.
Posted: Wed Aug 22, 2012 9:44 am
by Christine Grice
Or you can look at 20.10.C.4 in the ProSolo Rules
Posted: Wed Aug 22, 2012 10:37 am
Christine Grice wrote:Or you can look at 20.10.C.4 in the ProSolo Rules
That would require extra work :mrgreen:
