24' TPD Vortech
Posted: Sat Mar 16, 2013 8:57 am
by KJ Christopher
It would appear that I'm getting a new trailer (gooseneck with LQ), so the TPD Vortech needs to go. Asking $12,300.
Most of you are probably familiar with the TPD line, or at least have seen my trailer. TPDs are the best built out there in my opinion, and if you scan the used market, you'll notice the stable values reflect that. The Vortech model is built as a steel cage with a skin. (See brochure link below.) They don't twist and fall apart as they age. If you never needed more than a 24' enclosed, you'd never have to buy another trailer. And if you find yourself needing to upgrade like me, the resale market is kind to your investment.
Specifics for my trailer:
  • 2001 model
    24' box with sloped front
    10k gross weight rating, weighs 4k empty, so 6k capacity
    Tires new June 2011. Still in excellent shape. (Parked out of direct sun light.) I anticipated replacing in 2014 at the earliest. Unless you like doing donuts in the parking lot, triple axle tires are less stressed and tend to last longer than tandem axles.
    Two spares, wall mounted.
    A/C
    12v and 120v lighting.
    Shore power hook up to run A/C and 120v system. (This is where I connect my generator.)
    Folding table on side wall, permanent work bench in front.
    PitPal door cabinet/organizer/folding shell/paper towel holder.
    Lots of E-Track on walls and floor.
    Walls double as dry-erase boards to track settings, tire runs and other minutia or keep kids entertained.
I will be removing the 6' ramp and re-installing the short car ramp. If you need a WD hitch, I may sell mine separately.
Factory info on how it is built: http://tpdtrailers.com/wp-content/uploa ... ochure.pdf" onclick="window.open(this.href);return false;
Re: 24' TPD Vortech
Posted: Sat Mar 16, 2013 6:20 pm
by Toby Larsson
This will sell in a couple of days on trackhq.com.
It's generally frown upon if your first post is a for sale post. You will probably be fine since you know some of the regulars like Oli T Emilio Cervantes and Vincent Wong.
Re: 24' TPD Vortech
Posted: Mon Mar 18, 2013 10:16 am
by Vincent Wong
Toby Larsson wrote:This will sell in a couple of days on trackhq.com.
I didn't know you're on TrackHQ.com. :D
Good luck with the sale, KJ.
