Getting gas struts/gas spring damper modified?
Posted: Thu Apr 25, 2013 10:42 pm
by Q V
Does anyone know a local place that can lower the pressure of a tiny gas strut/gas spring damper?
If you know a place that sells these types of dampers, please also suggest - I have found a couple online ones & waiting on a quote from them; hoping to find something local
This damper currently supports something like 100-200lbs. I need it to just support 20lbs.
Re: Getting gas struts/gas spring damper modified?
Posted: Fri Apr 26, 2013 7:38 am
Have you calculated in the added weight of the hood ornament?
Posted: Fri Apr 26, 2013 9:23 am
by Bobby Beyer
Have you tried Mcmaster?
http://www.mcmaster.com/#gas-springs/=mho5mb" onclick="window.open(this.href);return false;
Posted: Fri Apr 26, 2013 10:04 am
by Q V
Steve Ekstrand wrote:Have you calculated in the added weight of the hood ornament?
This one's for another project, but thanks for reminding me - a hood damper would be pretty sweet, too!
Bobby Beyer wrote:Have you tried Mcmaster?
Thanks Bobby, I checked and they don't quite have the right specs.
I thinkI may have found something that may work - custom spec off Stabilus site. As long as it's not ridiculous expensive, I should be good.
