Valve Stem Recall? 2002?
Pete Loney
Car#: 777
Post by Pete Loney »
Never caught this back then but this article has some good valve stem info. for all of us car nutz.
http://www.popularmechanics.com/automot ... 82960.html" onclick="window.open(this.href);return false;
Has hysteria kicked in yet? Dill Air Control Products recently recalled 6 million Chinese-made tire valve stems that may crack and fail, letting air out of tires at speed and possibly affecting as many as 30 million vehicles. Wake up, folks! I've always recommended the use of metal valve stems, not rubber ones.
This story appeared in my column in PM in 2002, but apparently I need to go over this again. I'm not going to get into the fact that these valve stems were manufactured in China. Any rubber valve stem will eventually crack near its base and fail. We've seen a lot of buzz, probably started by a broadcaster on a slow news day, about old stock tires being recast with years well after their manufacture date. I've long had a policy of never reusing a rubber valve stem, period. If a customer of mine was too cheap to spring an extra five bucks for metal stems, I was okay. But I always install new rubber stems. And inspecting the stems was part of the checklist for any car that came into my shop before it went back onto the road, right along with checking the oil and torquing the lug nuts properly.
Here's how to check your valve stems: Get a flashlight, and maybe something to kneel down on. Hold the valve stem in your fingers, and bend it as far as you can in a circle. You need to visualize the rubber where it comes out through the hole in the rim, and you need to see all 360 degrees. Hose off any mud if you need toÑany evidence of cracking means that the stem needs to be replaced, immediately. I've done this and had the stem actually fail in my hand, breaking in half and venting all the air in the tire within a few seconds. That's exactly what you don't want to happen when you're on the freeway in heavy traffic. Don't forget to make sure the caps are installed over the valve in the stems, too.
