The OS Giken SoPac Super Regional Run/Work Order
CLICK HERE FOR RUN ORDER
This is 99.9% set, one class may be moved. Be sure to verify when you work, while for most it's with the same group you run with, a few classes are in different groups for working.
Re: The OS Giken SoPac Super Regional Run/Work Order
We will have three drivers in the 4th heat.
Will Kalman and Steve Ekstrand in STC and Stacey Miller in CSPL.
- Christine Grice
- Car#: 17
... Oops....Steve Ekstrand wrote:We will have three drivers in the 4th heat.
Edit: Revised run/work order should be posted soon.
Run/Work order updated. CSPL now runs 2nd and works 4th, although Stacey will be working 1st heat.Christine Grice wrote:... Oops....Steve Ekstrand wrote:We will have three drivers in the 4th heat.
Thanks for the quick solution. I should have tipped you guys off. Stacey was annoyed with running without competition again so I found her CSPL. She and Mitzi were within about a second of each other that the SD Tour so that looked more fun. For local points she is still STC indexed in PAXL.
Last edited by Steve Ekstrand on Tue Jun 18, 2013 1:49 pm, edited 1 time in total.
- Christine Grice
- Car#: 17
I knew exactly why Stacey was in CSPL (been there, done that), thought about it several times and then I double, triple checked the run order and spreadsheet for a day and a half before releasing it, I still missed it.Steve Ekstrand wrote:Thanks for the quick solution. I should have tipped you guys off. Stacey was annoyed with running without competition again so I found her CSPL. She and Mitzi were within about a second of each other that the SD Tour so, that looked more fun. For local points she is still STC indexed in PAXL.
Now if we could just get you to change your signature to "Grice", Marshall would quit calling us in the middle of the night (from work) asking "why won't she change it?" But then, Marshall Berry has a nice ring to it.Christine Grice wrote:I knew exactly why Stacey was in CSPL (been there, done that), thought about it several times and then I double, triple checked the run order and spreadsheet for a day and a half before releasing it, I still missed it.Steve Ekstrand wrote:Thanks for the quick solution. I should have tipped you guys off. Stacey was annoyed with running without competition again so I found her CSPL. She and Mitzi were within about a second of each other that the SD Tour so, that looked more fun. For local points she is still STC indexed in PAXL.
I think they should develop and market their own IPA called Griceberry Juice Cocktail. The label can have a giant Blackberry morphing into a hot rod and scattering cones while smokin all four tires.
Bill Schenker
Feel the love :heyes:
- Mark DeShon
- Car#: 113
Wow, Steve! I want whatever you've been smoking.Steve Ekstrand wrote:I think they should develop and market their own IPA called Griceberry Juice Cocktail. The label can have a giant Blackberry morphing into a hot rod and scattering cones while smokin all four tires.
Mark D.
Doesn't need such, he has something better/worse (depending on your perspective): it's called hyperactive young male child in house... induced insomnia!Mark DeShon wrote:Wow, Steve! I want whatever you've been smoking. Mark D.
Tonsilectomy in 12 days 18 hrs and counting down.....
Silence is coming.
Silence is coming.
Bill Schenker
For you?! Yes, that's the sound of 100's of people cheering...Steve Ekstrand wrote:Tonsilectomy in 12 days 18 hrs and counting down.....
Silence is coming.
But that won't affect your typing fingers...Steve Ekstrand wrote:Tonsilectomy in 12 days 18 hrs and counting down.....
Silence is coming.
