Question regarding motorsportreg
Posted: Mon May 12, 2014 9:44 am
by Stephen Strand
I am trying to sign up for the June 8th event. In motorsportreg it is asking me to choose my vehicle number, which after signing up for my points card is #915. On the drop down for vehicle number, that one isn't available. Is there a different way to go about this if you have a points card number?
Re: Question regarding motorsportreg
Posted: Mon May 12, 2014 10:05 am
by George Schilling
MSR is showing 915 registered to someone else and the number is active. Try sending a message to the points card chairman Kurt Rahn and explain the situation to him so he can make the correction.
Posted: Fri May 30, 2014 12:51 pm
George Schilling wrote:MSR is showing 915 registered to someone else and the number is active. Try sending a message to the points card chairman Kurt Rahn and explain the situation to him so he can make the correction.
Wow…been a while since I got on the message boards, I guess. The previous owner of #915, Jeremy Cottrell, didn't renew his points card according to my records. Steve, I removed his entry, so you should be able to sign up using 915 now.
Posted: Fri May 30, 2014 1:05 pm
by George Schilling
FYI Kurt, Jeremy has used that number in 2014.
Posted: Tue Jun 03, 2014 10:28 am
I'll try to contact him.
