August 20 TNT Request
Posted: Wed Aug 03, 2016 11:02 am
by Mike Yanase
What would be the necessary procedure to get this to happen?
I would like to volunteer to design the course. Hopefully that is enough for step 1
Re: August 20 TNT Request
Posted: Mon Aug 08, 2016 2:05 pm
by Mike Nakata
KJ...
Can we make this happen....I would really appreciate the opportunity an extra course for testing would provide....as nationals looms near....and few other opportunities are available....
Posted: Mon Aug 08, 2016 5:08 pm
by KJ Christopher
I've been discussing with the regional officers. We need to have a safety steward present at the TNT course. Would also need someone there to manage the course.
If these positions are filled from the general practice population, it may force us to move from the 5 group to a 4 group form format (to have adequate course coverage), and that would suck from a length of work session point of view.
There is the possibility that one could convince a couple people not in the practice to come out and fill these roles, such that it doesn't impact the worker pool. Or something in the middle, so we're note taking 8-10 people out of the worker pool.
And yes, this is a shift from prior years, where "go play nice" was deemed sufficient. Earlier this year, we had an experienced volunteer who set up and ran the course without actually being in the practice, which made it real easy to incorporate into Saturday. However, even looking back on that, we think it is prudent to have a safety steward there, given the distance between the main and TNT course.
Posted: Mon Aug 08, 2016 5:20 pm
by Kevin Pao
KJ, would it be possible to have a TnT course where there isn't any workers to pick up the cones? If the driver hits the cones, the driver go back out to pick it up and reset the course. This way there isn't any need to take workers from the main course.
I agree that there should still be a dedicated SSS there to oversee the TnT course.
Posted: Mon Aug 08, 2016 5:30 pm
by Mike Yanase
Kevin expressed the same feelings about how we implement a "shag your own cone" worker coverage for the course.
I highly doubt that we would have any space to run more than 1 car at a time on course, so I don't see that as much of a problem. It's not like there is a set amount of runs that we are promising to people, so having a bit of downtime between runs if the course gets destroyed shouldn't lead to any issues.
The only request that I would have to make this work is having the 2nd SSS pulled from the worker pool. This only subtracts one additional worker from the pool instead of the forecast of 8-10 you had stated earlier.
I think if we can make this possible and allow the "shag your own cone" policy, then hopefully we can get the go ahead!
Posted: Mon Aug 08, 2016 5:41 pm
by KJ Christopher
Kevin Pao wrote:KJ, would it be possible to have a TnT course where there isn't any workers to pick up the cones? If the driver hits the cones, the driver go back out to pick it up and reset the course. This way there isn't any need to take workers from the main course.
The intent isn't to have actual TNT course workers - has to be a shag your own cone deal. Just one person to run the course ("starter") and a safety steward as assigned worker positions. That's two people, times either 4 or 5 run groups, which is 8 - 10 people.
Posted: Mon Aug 08, 2016 5:57 pm
by Mike Yanase
KJ Christopher wrote:Kevin Pao wrote:KJ, would it be possible to have a TnT course where there isn't any workers to pick up the cones? If the driver hits the cones, the driver go back out to pick it up and reset the course. This way there isn't any need to take workers from the main course.
We can have a SCNAX member work as the starter on top of their standard work assignment for the practice.
Posted: Mon Aug 08, 2016 6:00 pm
by Sean Fenstermacher
KJ,
I think what Mike is requesting for is just 1 additional work exemption spot for the 2nd SSS position.
Posted: Mon Aug 08, 2016 6:19 pm
by KJ Christopher
If y'all can cover starter position, we can spare one worker position to cover SSS for the day. Would need to have a back-up ready for when the SSS runs (either course).
Mike Yanase wrote:We can have a SCNAX member work as the starter on top of their standard work assignment for the practice.
Sean Fenstermacher wrote:I think what Mike is requesting for is just 1 additional work exemption spot for the 2nd SSS position.
Posted: Mon Aug 08, 2016 6:44 pm
Thanks KJ!!
I can be the 2nd SSS if no one has stepped forward yet.
Posted: Mon Aug 08, 2016 7:11 pm
by Kevin Pao
Hi KJ,
Since I didn't register for the practice, I can be the "starter" for the TnT for the whole day if that will get us a TnT. Will that help?
Posted: Mon Aug 08, 2016 7:33 pm
by Anthony P.
Were you thinking a practice course or a slalom & skid pad?
Posted: Tue Aug 09, 2016 10:23 pm
by Steve O'Blenes
If we do fet to have a test course set up may i recommend a slalom on one side with offsets on rhe other side with a coned sweeper connecting the two sections for up and back along the runway. This way we can actually get a much better test to cover multiple aspects of a course and not just one.
Steve
Posted: Wed Aug 10, 2016 12:54 pm
by Q V
Steve O'Blenes wrote:If we do fet to have a test course set up may i recommend a slalom on one side with offsets on rhe other side with a coned sweeper connecting the two sections for up and back along the runway. This way we can actually get a much better test to cover multiple aspects of a course and not just one.
Steve
Are you also volunteering to help design course? I'm sure Mike would appreciate the help.
Posted: Thu Aug 11, 2016 10:03 pm
by Steve O'Blenes
Is he doing the main course. Would love to help if I am available. Will it be set up Friday or Saturday morning?
