Hot R Comp Rubber Collection
- Chad Stubblefield
- Club: Team Blew
- Car#: 877
Im kind of new to R comps (Hoosier A6) so have a heart.
I have been collecting a lot of abandoned rubber on my tires while on course and its been fusing with my tires.
It has actually filled in one of the groove lines completly.
I think this would effect the tire performance, am I right?
So do I use my first lap just to scrubb this off?
Do I need to worry about this at all?
thanks
thanks
Re: Hot R Comp Rubber Collection
Jeff Kiesel uses a tire scrubber - it's like a metal loofah!
Damn, is that what that was. He had me using it all wrong.Max Hayter wrote:Jeff Kiesel uses a tire scrubber - it's like a metal loofah!
The tire scrapers are available at C2 Motorsports. They're inexpensive and work great. Give Steve a call. Their banner is on the Solo2.com site.
Last edited by George Schilling on Wed May 28, 2008 12:14 pm, edited 1 time in total.
I use a small hand held torch and a putty knife to remove build-up, works great.
Jeff and Nicole have been wondering where THEIR rubber has gone ... please get in touch with them so that you can return it.
Most people complain about going through their R's. You should be happy!
- Chad Stubblefield
- Club: Team Blew
- Car#: 877
these Hoosiers have been holding up nicely 40+ runs. But Maybe Im not going fast enough to kill em.
Jeff is more than welcomed to come and peel his tires off mine.
- Chuck Fowler
- Club: Team Blew
- Car#: 299
ooh ooh let me tryChad Stubblefield wrote:these Hoosiers have been holding up nicely 40+ runs. But Maybe Im not going fast enough to kill em.
Jason, given that race tire life is often measured in heat cycles rather than calendar age, are you concerned what the flame contact might be doing to the good rubber? I realize it's brief, and mostly directed to the pickup, but I'm sure it would seriously blister your skin...might it not cause at least surface damage to the rubber?Jason Isley BS RX8 wrote:I use a small hand held torch and a putty knife to remove build-up, works great.
I grind off the pickup with a 5" disc grinder fitted with a stiff wire brush cup. And try to limit the brush contact to the pickup. But I'm sure the result isn't as good looking as you can get with a torch and spatula.
If I was worried about "heat cycles" I would not drive to events on my tires either.Bill Martin wrote: Jason, given that race tire life is often measured in heat cycles rather than calendar age, are you concerned what the flame contact might be doing to the good rubber? I realize it's brief, and mostly directed to the pickup, but I'm sure it would seriously blister your skin...might it not cause at least surface damage to the rubber?
Just like your method, I only heat up the area with the rubber pick-up, which is not the whole tire.
And also the sponsors are at the bottom of all forum pages.George Schilling wrote:Their banner is on the Solo2.com site.
But they are not hot links, which they probably should be.Giovanni Jaramillo wrote:And also the sponsors are at the bottom of all forum pages.George Schilling wrote:Their banner is on the Solo2.com site.
- Steve Coe
- Car#: 75
George Schilling wrote:Damn, is that what that was. He had me using it all wrong.Max Hayter wrote:Jeff Kiesel uses a tire scrubber - it's like a metal loofah!
Thanks for the plug George! I'll bring some up at the next event. Look for a red STS2 Miata #935
Is he using the Rocks Off device for this?Max Hayter wrote:Jeff Kiesel uses a tire scrubber - it's like a metal loofah!
