Christine Berry wrote:Actually, after playing with excel formulas for a while it is now mostly done by formulas, not by hand.
=small(...)
=vlookup( ...)
=iserror(...)
=if(...)
are my new friends
only way to speed up the process now is to have Rick output the PAX results with just: number and indexed time.
If he does that, wouldn't Xcel be able to link to a database of names? I'd think the results could be exported tab or comma delimited, too.
thanks Christine...now if i can figure out what the heck you guy's are talking about
vlookup is a table to "look up" values hence the name "vlookup". "is error", "if" (self-explanatory). "small" is basically "floor" or "rounding down to the nearest thousandth".
Bob Beamesderfer wrote:I should've kept going on Frontier and PERL scripting. I also used to know how to write GREP expressions.
If you know PERL, you can get a job in I.T. writing it (Unix is the platform).
I know; never got far enough; it's not an easy language, quite verbose. Frontier was much more elegant and fairly powerful, ran on Mac or Windows, but it's now outdated. Frontier's author, Dave Winer, created the first blog software.
Steve Ekstrand wrote:You want outdated? I programmed in MUMPS for the Mayo Clinic in the early 80's as a teenager.
MUMPS at the Mayo Clinic? Is that some sort of joke?
I haven't heard of MUMPS and my father and brother both were quite active in the languages for their respective jobs. Well, my brother still is. ;)
Steve's right. There was a language called "MUMPS", along with Ada, Fortran, Pascal, Assembly, PL/1, Smalltalk, C, C++, C# (aka C Sharp), Java, PL/SQL, Perl, etc...........
I developed a system to collect laboratory testing equipment results and add it to a patient database basically automating what had previously been a manual process. It worked pretty well til we could no longer buy PC's with cassette ports. I used the cassette ports as a programmable on-off switch for the lab equipment. It was pretty basic... I'd prefer to describe it as elegant. The DEC engineers said it couldn't be done for less than the GDP of a small country. 4 months later we invited them back.... They offered me a job. I thought I could make more money as an attorney. MUMPS was actually a very good language to use for the project, its sort of what it was designed for originally.
You forgot Cobol and RPG II. [ex IBM System 3 Models 10 and 15 operator here.] I wonder what a 370 mainframe goes for these days? Probably less than the scrap price.
Christine Berry wrote:I am certainly not a programer so almost everything you guys have said has gone over my head.
However, Gio, in excel the small formula takes a range and returns the smallest values in it. Its the way I calculate the drops.
That was my guess but now I remember! I had to do this to calculate the year-end averages back when I was using Tony Payne's scripts and only the word "AVG" was in the excel spreadsheet. Then at the end of the year I had to calculate and it used the function called "small".
Which in Oracle the function is called "least" and you provide it a set of values. The opposite would be "greatest".
You're an engineer by trade like me, just a different specialty (mechanical vs. software), so you would pickup programming easily Christine. Which aero company are you with Raytheon, or Boeing?
