When we weighed too, we full truck tanks, Julie and I in the cab, full black and grey tanks that are ahead of the trailer axles and extra luggage stowed in the master bedroom. It was about as much tongue weight as we could ever achieve. Pluss we stored more heavy stuff in the front underbed that will eventual go on the wall over the trailer axles. Plus were nosedown about 3" from where I'd like it. Fix all those things and I think we'll have a proper truck rear axle weight. Definitely going to have to watch those rear tires. I thought it had a tire pressure monitoring system, but I guess it was an option, I can't find the button where it shows in the manual. I thought it was on my sticker, I'll have to check. Just not sure where I put that....
BTW- David, I checked the trailer labels, empty weight is 11,484lbs.
And the waste tanks are labeled correctly, the guages are just very very flaky.
Oh, and Julie's waste products must have been very very caustic.....
:barf:
The sewer hose sprang a leak on its third use...
