SCNAX CUP XI 2016: Eleven times the Cone-liciousness!
The infamously-famous SCNAX Cup is back again for a one-day TEAM competition happening on Saturday October 22nd, 2016 that lets you test your driving skills in different cars against other drivers!
Teams consisting of 3 drivers in 3 cars compete against each other in a battle of driving skill, precision, and wits in order to see who is the fastest to win the SCNAX Cup!
Drivers:
3 drivers, 3 cars (2 okay for teams w/normal co-drivers)
*NEW FOR 2016*: ALL cars on a team can have the SAME drivetrain! (all FWD, RWD, AWD, Kart/UWD)...
……BUT if one of the cars is of a different drivetrain, that team will get a “special” handicap/multiplier/addition/subtraction etc. to be determined which will help in netting a LOWER total time for their team.
Example: 2 miatas, 1 Subaru WRX.
3 cars is still HIGHLY recommended for logistics & fun purposes
Competition:
Saturday, only 4 runs per driver in each car (3 cars x 4 runs per car= 12 total).
Team Points - The BEST RUN for each driver in each car COUNTS ONLY! (For 2 car teams, best time in each car, but car w/2 times must be from different drivers). Points/times are off indexing system (combination of car class time + driver indexing below), not raw time.
Numbering:
Number system is similar to Nationals/Regionals - xx, 1xx, 2xx; no local numbers, easier to keep track of teams
The basic format is choose a 2 digit # (give me your first, second, and 3rd choices), your numbers will be:
## - Driver 1 (Team Captain)
1## - Driver 2
2## - Driver 3
(aka Super extended Nationals style multi driver numbering system)
Indexing System:
With each entry, you will be required to provide their most recent 3 event results for indexing (we will only count 2012-2016) - event date, your car class, your pax time, and top pax time of that event. In addition:
- if you do not supply it, you will run some default handicap (based on class leader or something of our choosing).
- if you don't have 3 events between 2014-2015, we will average out however many they have run and/or add a default handicap depending on situation (again of our choosing)
- if you lie about your index, you will run some default handicap + extra punishment (evil punishment to be determined
And *NEW for 2016*: If your team has at least one car that is a different drivetrain from the rest, a special handicap/multiplier/addition/subtraction etc. (to be determined) will be applied that will lower your team’s total time. Yes, that's right!
The SCNAX CUP will be awarded to the FASTEST team!
AND trophies will be given out to the 2nd and 3rd place teams along with these awards:
> "MVP" Most Valuable Pax - The driver with the lowest raw time (before driver's PAX)
> "MVC" Most Valuable Car Award - The car with the lowest total PAX Time
> "MVD" Most Valuable Driver Award – The driver with the lowest fully indexed total time ;)
Other awards to be determined as the event draws closer...
SO can YOU turn the knob up to ELEVEN and WIN this eleventh edition of the SCNAX CUP???
ARE you ready to engage in a little friendly one-upmanship for BRAGGIN' RIGHTS, KUDOS, and CHEETOS???
THEN Please do these 2 things:
1.) Register for the October 22nd Practice
https://www.motorsportreg.com/events/le ... cca-286235
AND
2.) ALL SCNAX CUP competitors, please fill out this google form :
https://docs.google.com/forms/d/e/1FAIp ... rm?c=0&w=1
THANK YOU and see you ladies and gents out there!!!
