Course Setup for September 29-30
- Reed Gibson
Hey Everybody!
I'd like three helpers for Friday set up and two more for Saturday change over. Plan to start around 2pm on Friday and finish hopefully by 6 pm. Let me know if you'd like to help out! This will count as your work assignment for the next day.
Friday:
1) Vereker Tam
2) Pete Loney
3) Mo Al Rawi
Saturday:
1) Tom Frecentese
2) David Watson
Friday:
1) Vereker Tam
2) Pete Loney
3) Mo Al Rawi
Saturday:
1) Tom Frecentese
2) David Watson
Vereker Tam
Re: Course Setup for September 29-30
I can help out friday.
- Reed Gibson
Awesome, I will see you there!Vereker Tam wrote:I can help out friday.
Mo Al Rawi
I can help on Friday. I can be there around 2:30. Is that OK?
- David Watson
I can help with changeover Sat. afterwards.
1999 Mazda Miata, Lewis Hamilton, Ron Fellows, David Coulthard, Jacques Villeneuve, Laguna Seca, Spa Francorchamps, Racetrack of the Americas, Long Beach Grand Prix since 1992, Circuit De Gilles Villeneuve 98 -99, VARA Willow Springs BF Goodrich
Powerglide
I can help with Sat. change. Thanks. - Tom F.
- Reed Gibson
Perfect you're inDavid Watson wrote:I can help with changeover Sat. afterwards.
- Reed Gibson
Sounds good Tom!Powerglide wrote:I can help with Sat. change. Thanks. - Tom F.
- Pete Loney
- Car#: 777
I am looking good to be available on Friday about 1:00 PM
Will be in Fountain Valley at 11:00 beforehand at Steve Lepper's shop.
A favor, please cull out any really bad cones you come across while you are setting up. Need to reduce the amount of cones in the motor home. Thanks.
- Reed Gibson
Perfect! You'll round out the gang then Pete.Pete Loney wrote:I am looking good to be available on Friday about 1:00 PM
- Q V
- Car#: 69
How many are we trying to get rid of? Maybe I can help remove really bad cones & donate some marginal cones for local FSAE practice?Rick Brown wrote:A favor, please cull out any really bad cones you come across while you are setting up. Need to reduce the amount of cones in the motor home. Thanks.
At least the amount that is stacked on the passenger side. We don't really need more than will easily fit in the designated area on the driver's side.Q V wrote:How many are we trying to get rid of? Maybe I can help remove really bad cones & donate some marginal cones for local FSAE practice?Rick Brown wrote:A favor, please cull out any really bad cones you come across while you are setting up. Need to reduce the amount of cones in the motor home. Thanks.
- Reed Gibson
I'll create a pile of discards and donates to get us down to a more appropriate level for our storage capacity.Rick Brown wrote:At least the amount that is stacked on the passenger side. We don't really need more than will easily fit in the designated area on the driver's side.Q V wrote:How many are we trying to get rid of? Maybe I can help remove really bad cones & donate some marginal cones for local FSAE practice?Rick Brown wrote:A favor, please cull out any really bad cones you come across while you are setting up. Need to reduce the amount of cones in the motor home. Thanks.
- Reed Gibson
Slight change of plans everyone. Looks like we can't get onsite for setup Friday so we'll need to do it Saturday morning instead. Please let me know if you can accommodate coming at the crack of dawn for Saturday morning setup now so I can plan accordingly!
Mike Flanigan
If Ortega is clear on Saturday morning early.......I'll be there to help.
- Reed Gibson
Awesome, thanks for always volunteering to come help out Mike, we appreciate it!Mike Flanigan wrote:If Ortega is clear on Saturday morning early.......I'll be there to help.
- David Watson
Hi Reed,
I can get there early Sat.
And I'll be there early (though not as early as you guys) to set up timing and the motor home.
- Reed Gibson
No worries David, we are accounted for with workers for the wee morning hours. We'd definitely appreciate help chalking the course closer to the start time though!David Watson wrote:Hi Reed,
- David Watson
Hi Reed,
what time should I arrive by?
- Reed Gibson
We probably won't need any extra hands until 8:00 am. No worries on showing up early, you're fine just helping out for the changeover after the event.David Watson wrote:Hi Reed,
- David Watson
Cool, see you tomorrow!
