Find Aaron a ride
Re: Find Aaron a ride
... oh, and the car can't be TOO Small. ;)
aaron has the benefit of being taller in the torso, than the legs, so i think he actually has less problem than your other 6'4 people. i'm not sure how much that helps in squeezing into a mini or a miata though..Mako Koiwai wrote:... oh, and the car can't be TOO Small. ;)
- Max Hayter
- Car#: 31
He 's a little tall for a Miata, but surprisingly, would easily fit in a MINI.Jeff Shyu wrote:aaron has the benefit of being taller in the torso, than the legs, so i think he actually has less problem than your other 6'4 people. i'm not sure how much that helps in squeezing into a mini or a miata though..Mako Koiwai wrote:... oh, and the car can't be TOO Small. ;)
Bill Schenker
- Car#: 14
That's disgusting!Max Hayter wrote:He does have unnatural proportions!
- Max Hayter
- Car#: 31
Bill Schenker wrote:That's disgusting!
- Michael Palero
- Car#: 18
So Max, just how unnatural are his proportions?
- Casey Brier
- Car#: 806
:barf: HHAHAHAHA
Jason Rhoades
STU TT Supra on a big open concrete lot = fun. Why not give it a try? Your chances for a win might be better overall as the "Starter" in your own car, then as second-string in someone else's. It's one of only a few cars under 3300lbs. that can fit 285's at all 4 corners and makes good power.
Jason Rhoades wrote:STU TT Supra on a big open concrete lot = fun. Why not give it a try? Your chances for a win might be better overall as the "Starter" in your own car, then as second-string in someone else's. It's one of only a few cars under 3300lbs. that can fit 285's at all 4 corners and makes good power.
That's what I'm sayin'! ;)Sebastian Rios wrote:He has an STU car now that the TT ban has been lifted.
i think he was planning on using the 2009 year to develop the supra, but still wanted to compete in a viable car for 2009.
maybe what aaron needs, is a codriver in the supra to help him develop it. sounds like something that he can sucker marshall into ..
...but 285/30-18 neova cost more then 285 hoosier A6's. and he'd have to turn down the boost.Jeff Shyu wrote:i think he was planning on using the 2009 year to develop the supra, but still wanted to compete in a viable car for 2009.
Bill Schenker
- Car#: 14
WHAT?! When Marshall has the sweetest co-drive in AX history?! (the girl, the car, finally a Berry son...) I DON'T THINK SO!Jeff Shyu wrote:... something that he can sucker marshall into ..
Bill Schenker
- Car#: 14
Oh, and least I forget: the softest PAX in '09!
- Tom Berry
- Car#: 72
Those darn grapes are soooo sour.
Giovanni Jaramillo
OUCH! Bill you got OWNED big time!Tom Berry wrote:Those darn grapes are soooo sour.
Bill Schenker
- Car#: 14
I like 'em in my oatmeal every morning...
Bill Schenker
- Car#: 14
When you actually show up to an event, you can say something; 'til then - back in the trunk!Giovanni Jaramillo wrote:OUCH! Bill you got OWNED big time!Tom Berry wrote:Those darn grapes are soooo sour.
Giovanni Jaramillo
Don't need to show up. I just look at the standings and it's a BSP driver on top in PAXBill Schenker wrote:When you actually show up to an event, you can say something; 'til then - back in the trunk!Giovanni Jaramillo wrote:OUCH! Bill you got OWNED big time!Tom Berry wrote:Those darn grapes are soooo sour.
Jason Rhoades
No better way to develop a car than by competing in it in National events.Marshall Grice wrote:...but 285/30-18 neova cost more then 285 hoosier A6's. and he'd have to turn down the boost.Jeff Shyu wrote:i think he was planning on using the 2009 year to develop the supra, but still wanted to compete in a viable car for 2009.
The 285 GTR Dunlops are even more than Neovas, but would still have a better $ per competitive run profile than the Hoosier.
Supra boost controls are entirely mechanical, so as long as the boost controller is tossed and the stock devices kept you are ok. If it decided when stock to stop feeding fuel at 15psi, it doesn't necessarily have to behave that way in ST, since it is a fueling decision it makes, not a boost one. At least, that's one interpretation.
JRho--- You really like the GTR's? Isn't that the run flat tire?
And Bill.... PAX runs first heat. You are soooo dead.
Jason Rhoades
Even if the Dunlop's grip is only as good as a Neova or RE01R, its extra size and thermal capacity should help a somewhat under-tired car last longer before overheating its tires.Steve Ekstrand wrote:JRho--- You really like the GTR's? Isn't that the run flat tire?
The 240 was 650lbs. (over 30%) heavier than its competition, and only had 10-20mm more tire on same-width wheels. It could keep up for a while but on a longer course, or with too-high temps, the tires would just plain overheat. It helped me that it was about 50 degrees both days in Topeka, and I still had to water the back tires.
The Supra will only be a little bit heavier than the Evo and Sti (but much better balanced), and it gets 40mm more tire.
Bill Schenker
- Car#: 14
And don't you think I already knew that (on both counts)?!Steve Ekstrand wrote:...And Bill.... PAX runs first heat. You are soooo dead.
your numbers are a little.. optimistic. ;)Jason Rhoades wrote: The 285 GTR Dunlops are even more than Neovas, but would still have a better $ per competitive run profile than the Hoosier.
Supra is just getting a repaint and some mechanical work done, and I'm sure Marshall has his pick of much better rides than anything I own.Jeff Shyu wrote:i think he was planning on using the 2009 year to develop the supra, but still wanted to compete in a viable car for 2009.
