SIZES AVAILABLE
http://bridgestonetire.com/tireselector ... ct_ID=2033
Pricing
195/50r15 Bs Poz Re-11 119.00
205/50r15 Bs Poz Re-11 124.00
205/45r16 Bs Poz Re-11 Xl 164.00
205/55r16 Bs Poz Re-11 148.00
225/50r16 Bs Poz Re-11 161.00
205/45r17 Bs Poz Re-11 Xl 173.00
215/45r17 Bs Poz Re-11 Xl 182.00
225/45r17 Bs Poz Re-11 Xl 191.00
235/40r17 Bs Poz Re-11 203.00
235/45r17 Bs Poz Re-11 Xl 209.00
245/40r17 Bs Poz Re-11 221.00
245/45r17 Bs Poz Re-11 223.00
255/40r17 Bs Poz Re-11 231.00
225/40r18 Bs Poz Re-11 Xl 221.00
225/45r18 Bs Poz Re-11 247.00
235/40r18 Bs Poz Re-11 Xl 253.00
245/40r18 Bs Poz Re-11 Xl 261.00
245/45r18 Bs Poz Re-11 Xl 260.00
255/35r18 Bs Poz Re-11 278.00
265/35r18 Bs Poz Re-11 288.00
265/40r18 Bs Poz Re-11 Xl 282.00
225/40r19 Bs Poz Re-11 Xl 244.00
235/35r19 Bs Poz Re-11 Xl 272.00
245/35r19 Bs Poz Re-11 Xl 284.00
255/35r19 Bs Poz Re-11 Xl 295.00
265/35r19 Bs Poz Re-11 Xl 307.00
275/30r19 Bs Poz Re-11 Xl 306.00
305/30r19 Bs Poz Re-11 335.00
ONLINE PICS:
Designed with the performance enthusiast in mind, the Potenza RE-11 brings together many of Bridgestone's technologies in one impressive package. With a unique new sidewall shape and radical new "stealth" block derived from our Formula One (TM) race tires, the new Potenza RE-11 boasts the significant level of grip and handling for the street and track--and it will ignite your adrenaline in the process.
Stealth Blocks
Promotes higher tread stiffness while enhancing water evacuation.
Large Outer Tread Blocks
Improves cornering performance.
Circumferential Grooves
Helps channel water out of the footprint area to improve resistance to hydroplaning.
Asymmetric Construction
Optimizes handling and ride characteristics with a special sidewall construction that varies from inside to outside.
Warranty Summary:
Platinum Pact Limited Warranty
Standard Limited Warranty
UPDATE...
Comparision photos
"Here are two pics of the new RE-11's. The first is of a 205/50/15 and measures right at 8.35 inches wide. The second pic is of a 195/50/15 and measures 7.95 inches wide. So, almost a half inch difference between the two. Just FYI."
205's
195's
