The new look of F1
Re: The new look of F1
Post by Marshall Grice »
Sebastian Rios wrote:The steering wheels are ridiculous, more buttons and knobs than a 747.
Edit: Why do they practice or test on wets when it's dry out?
I can assure there are WAY more buttons in a 747!
it's fairly standard for the team to do the installation lap on a set of inter's. saves runs on the good tires for when they really want to go fast.
Yeah, gotta make sure stuff isn't going to fall off.
Renault:
Williams:
so, the 2 change per lap rule on the front wing.
if you're approaching the front straight, level out the front wing, for a bit more speed, and as you're approaching the braking zone, you adjust it back. does that constitute 2 changes? or is that 1?
is there a minimum duration before it registers as "change"? ie, if a driver thought he had a passing opportunity, but the guy next to him went kerplowie as he was making the change, and he immediately changes the angle back?
the adjustable front element seems to be one of those things that would allow the leader to really extend the lead if he doesn't have to deal with defending, and can just optimize the wing for speed?
What a bunch of lamers.... Allow an adjustable wing them limit how many times you can use it. Do they work in government?
and what constitutes driver adjusted?
i'm guessing the wing's not adjusted via mechanical cable attached to a lever in the cockpit, so it must be some electronic knob on the steering wheel hooked up to a pneumatic arm.
can the angle then be made to be "computerized" so that at the push of a button by the driver, the attack angle be changed gradually but consistently (say, a braking zone, or coming onto a straight from a tight hairpin? angle would be changed based upon speed and maybe G load?) over a period of 2-3 seconds?
what about varying the angles separately on the left and right side?
Jeff Shyu wrote:and what constitutes driver adjusted?
why don't you tell us?
http://www.fia.com/sport/Regulations/f1regs.html" onclick="window.open(this.href);return false;
Marshall Grice wrote:why don't you tell us?
3.18 Driver adjustable bodywork:
a single closed section situated each side of car centre line in the volume bounded by:
- lines 450mm and 800mm in front of the front wheel centre line;
- a vertical plane which intersects these lines at a distance 250mm from the car centre line;
- and the inboard face of the body work described in artical 3.7.5;
is allowed to change incidence while the vehicle is in motion within a maximum range of 6*, provided any such change maintains compliance with all of the bodywork dimensional regulations.
alteration of the incidence of these sections must be made simultaneously and may only be commanded by direct driver input and controlled using the control electronics specified in article 8.2. Except when the car is in the pit lane, a maximum of two adjustments may be made within any single lap of a circuit.
and i didn't bother typing up article 8.2, but there's nothing specifying any further the degree of driver input. in fact, it makes a lot of connections to the ECU, making it each easier case to let the ECU feed info to the steering wheel.
i dunno, it seems like there's no rules against having the ECU figure out the optimal angle for the front wing at your given speed, and then letting the driver push a button to tell the ecu to "make it so". definitely nothing about the time taken to make the adjustments.
there's some additional stuff saying that the telemetry devices can't be hooked up to actuation devices, etc, but i think that's really more of a gray area on exactly where the "driver control" falls inline of the whole thing.
i think the whole driver adjustable front wing opens up a barn door of possibilities that wasn't fully thought out.
Jeff Shyu wrote: i think the whole driver adjustable front wing opens up a barn door of possibilities that wasn't fully thought out.
accept for the fact that they are controlled by a FIA spec ecu.
the driver must activate something to get the wing to move.
the ecu sends a signal.
in order for a driver to be able to adjust in 6* range, the most rudimentary form would be some sort of turn knob that's like a potentiometer. that electrical signal must be sent to the ECU to actuate the solnoid. the same programing inside the ECU must allow for preset angles so that rather than a potentiometer, a team can elect to have only 2 positions, max and min adj angle. given those limitations within the ecu, and incorporating both system, i don't see why there couldn't be a pushbutton activation that would send a time delayed voltage reading to the ECU to slow down the wing actuation?
BMW
Q&A about 2009 rules changes with Charlie Whiting, F1 Race Director:
http://www.grandprix.com/ns/ns21143.html" onclick="window.open(this.href);return false;
Despite the return of slick tires, the stupid two-compounds per race rule still exists. :roll:
Renault's new test driver:
isn't he too tall for F1?
Bob Beamesderfer wrote:Renault's new test driver:
Hey look...Villeneuve is back!
Bill Schenker
Car#: 14
Post by Bill Schenker »
ROTFLMAO!
Red Bull Racing:
haha.. 2nd picture:
redbull gives you [much smaller] wings.
Here's their weird "bulbous bow" diverter in front of the splitter?
That is bizarre looking, but Newey is quite the master of aero design.
From Naval Architecture:
Bulbous bow: A prominent appendage attached to the bow in order to reduce resistance and thus reduce required horsepower.
Mako Koiwai wrote:From Naval Architecture:
I knew I'd seen something like it before. America's Cup yacht?
any modern container boat or oil tanker:
Post by KJ Christopher »
I like the way it just makes it skim across the top of the water, removing all that hydrodynamic drag.
