Well run event.....very nice course........and I'm sure the first group appreciated it was cleaned prior to their runs :gpower:
Thanks again for a fun day! Steve
A well designed course (as this was) will be worker friendly. I worked area 1 for 2nd group & a few cars pushed out thru the wall and clipped the end cone, one driver got 3 plus one more for a bonus as he reentered. But really not overly busy there.Mako Koiwai wrote:Really like the course! Those mid course sweepers were challenging ...
Thanks for getting the course cleaned up before the first run group.
Did anyone think it was a bit too long? Were the workers spread out a bit too thin? Since we're doing the next El Toro course, we wanted some feedback ...
Thanks for the compliment Mako. Do you still think it was similar to the PCA course now that you drove it?Mako Koiwai wrote:Really like the course! Those mid course sweepers were challenging ...
+1 The lining really helped as I tried to show a couple novices how to follow the course and not get lost.Mike Simanyi wrote:Also, plan to line the course for the Championship. We have two liners now so two people can team up and get it done in a reasonable amount of time.
and DO set up everything you possibly can and get everything ready you can on the practice day. Try to never say, "we'll just do that in the morning on Sunday."Mike Simanyi wrote: Mako, I think it can work well in that space if the course has lots of runoff room so the workers aren't scrambling on cones. The big tip I can give you is to go with 5 worker stations though. With the default 4 on our worksheets, it makes for a very large amount of turf each workstation has to cover.
LOL, I already have plans for my own hatch to compete in SM, but first I'm gonna aim for STX and see how that goes with the stock motor before I swap it and go SM.Steve Ekstrand wrote:Great to see you come out to an event Web!
I found the PERFECT car for you!
http://sccaforums.com/forums/thread/325291.aspx" onclick="window.open(this.href);return false;
That would raise other complications.Webster Jessup wrote: I know I new to this, but some things I saw during the event were:
1) Too many x-runs. They should be limited to the end of the day like a group 7 if this happens quite often.
Agree,Bob Beamesderfer wrote:That would raise other complications.Webster Jessup wrote: I know I new to this, but some things I saw during the event were:
Well, like I said, only if it happens quite often.Bob Plante wrote: Agree,
x runs need to be spread around & most clubs are doing an ok to good job.
Your interest and suggestions are good. However, we try to allow people to either run and work in the morning or afternoon (some people do have a life outside Solo). When we used to have larger turnouts (300+), we split the groups so there were 4 in the morning and afternoon. Then we were able to allow a group in between working and running. With the smaller turnouts we have been having lately, that just isn't possible. If the turnouts increase, we will do that again.I also noticed that the run-work schedule was not efficient at all. Groups 1,2,4,and 5 all had work immediately following their runs. It should be arranged so that there is a minimum one group gap between runs and work. That way workers can be ready to go and same with the cars.
Run Work
1 3
2 5
3 1
L
4 6
5 2
6 4
The reason people had to work right before they ran was because they moved some of the groups around for this event to make the worker load more even. That should be fixed by the next event, the board just needs to permanently move a couple classes around which will move their work groups and even things out. I agree running right after working isn't fun.Webster Jessup wrote: I also noticed that the run-work schedule was not efficient at all. Groups 1,2,4,and 5 all had work immediately following their runs. It should be arranged so that there is a minimum one group gap between runs and work. That way workers can be ready to go and same with the cars.
Thanks for the feedback Web. Things that new people see are important to us. In this case, we have already discussed those issues and others, on the private Executive board. These are things we come up against periodically and sometimes there simply isn't an easy fix at the time it occurs. Part of being an all volunteer organization with varying groups of people putting on events. But feel free to continue giving us feedback, it helps to make us better (and eventually gets you nominated for a Board positionWebster Jessup wrote:I had no idea what I was missing. Thanks Mike for introducing me, and good seeing you again Ekstrand. I should have been autoxing since college. This was my first autox event ever and I have to say thanks to everyone who contributes to making these events happen. Good ethics on everyone working. I like how the whole system works.
2) I hear that this was a long course and based on other event times, IT IS! I don't think the groups worked well. There were fast cars ending up catching the slower cars and re-running 2-3 times. I worked grid 4 at the end and when the cars catch up to each other and the slower one knocks a cone down, workers don't have enough time to put back the cone before the fast guy comes around -> re-runs again.
3) Allow space for Novice drivers. The starting guy should wait a bit for the next car if a Novice driver is out. This is probably what messes up the groups.
4) Along with what Aaron said about the grids being clearly separated so workers and chiefs know what they are responsible for; there also needs to more print outs of the works grids.
Thanks again everyone,
Web
