Braille Battery Install with Pics
John Terrey
Re: Braille Battery Install with Pics
Hello All,
Please excuse the empty post before. Hopefully this works and the pics will be viewable for all. My OEM battery was aging and I decided to replace with a 15lb Braille battery. I could go lighter but this is a daily driver so I was a little conservative. After I sheared abolt it became apparent that I would need to double down and get the Brailler bracket. Here's some pics of the install which was much easier than I anticipated. The final outcome looks very nice- too bad you can't see it unless the carpet is removed!
Here's my OEM or at least the battery that came with the car.
Notice sheared bolt.
Here's the broken support tray that also required the Braille bracket.
Here's the batteries side by side.
I'll add a few more posts to complete.
John Terrey
Here's the Baseplate and Bracket
Here's the guide marks I made with a grease pencil for the screws that drill through the floor pan.
And here's those screws and 1mm washers required to secure the top cross bracket at the proper elevation
- Screws and washers
- Washers&Screws.jpg (51.83 KiB) Viewed 14350 times
John Terrey
Here's the baseplate after drilling into the floorpan!
Here's the completed bracket assembly. The key is to add the 1mm washer to each side so the top cross bar doesn't crush the battery. Make sure you do this before you screw it into your car.
Next, place the battery in the bracket attach the cross bar, tighten and you're done!
I've been driving the car daily without incident. I make a point of it to never leave the radio or lights on without running the car and all has been fine. The morning starts are quick and powerful.
I'll update if there are any developments. Please let me know if you have any other cool battery advice. Next I'm on to a light weight muffler. Any suggestions would be appreciated. My goal is to keep the car a daily driver so the noise level must be reasonable. Thanks!
My only suggestion is to disconnect the battery if you're going to leave the car for a week, i'm on my second braille right now.
- Christine Grice
- Car#: 17
Aaron Goldsmith wrote:My only suggestion is to disconnect the battery if you're going to leave the car for a week, i'm on my second braille right now.
http://www.amazon.com/Easy-Battery-Cut- ... sim_auto_4" onclick="window.open(this.href);return false;
John and I have been talking lighter replacement batteries for a while. He went with the 5 Star set-up. I went with the the low rent, lighter, non-daily driver Miata, Deka Power Sports AGM ATV Motorcycle Battery ETX9, about 5 lbs ... $55 plus $12.35 shipping. Arrived in two days from Pennsylvania, Fedex. I also bought a Battery Tender Jr, $24 something on eBay, to keep it charged between events. SAE terminals were another $11.
I'll be cobbling up a mounting system for it at Henry's workshop. Andy's Miata install write up: http://tinyurl.com/cgdykn
Photos to follow.
Photos to follow.
- Deka-Battery.jpg (86.01 KiB) Viewed 14229 times
John could have bought the deka Etx14 and ended up with the exact same battery he has now for half the price.Mako Koiwai wrote:John and I have been talking lighter replacement batteries for a while. He went with the 5 Star set-up. I went with the the low rent, lighter, non-daily driver Miata, Deka Power Sports AGM ATV Motorcycle Battery ETX9, about 5 lbs ... $55 plus $12.35 shipping.
Here' the bracket I made for my Odyssey:
Note the ground runs through the mount:
Last edited by Bob Beamesderfer on Fri Apr 17, 2009 9:38 am, edited 1 time in total.
i'm kind of surprised that works. the single point contact of a j-hook is far from the ideal ground path.Bob Beamesderfer wrote: Note the ground runs through the mount:
Two J-hooks.Marshall Grice wrote:i'm kind of surprised that works. the single point contact of a j-hook is far from the ideal ground path.Bob Beamesderfer wrote: Note the ground runs through the mount:
I might return it to it's normal spot, which is a 10mm bolt into the chassis a few inches above where it is now. There was less strain with the current setup.
Here's my low rent battery tie-down ... battery is 6 X 4.25 X 3.5 (W/H/D)
"Hard" foam underneath and between strap and battery top.
Do you think I should have crush tubes between the Miata battery tub base and the strap?
- Deka-Battery-TieDown.jpg (81.56 KiB) Viewed 13959 times
Michael Heinitz
- Car#: 73
Although a different generation Miata, here is my Odyssey 545 and custom mount.
Installed ... a 4X4 Deck Post Tie fits perfectly over the 3.5" wide Deka ETX9 battery:
- Miata-Battery-nuts.jpg (132.79 KiB) Viewed 13916 times
- Miata-Battery-Install2.jpg (114.25 KiB) Viewed 13917 times
- Miata-Battery-Installed.jpg (102.02 KiB) Viewed 13915 times
- Todd Victoria
- Car#: 79
Will the Braille bracket work with the Deka battery?
Not that particular Braille top ... there are many sizes of Braille/Deka batteries and hold down straps.
- Chad Stubblefield
- Club: Team Blew
- Car#: 877
i got a Braille with this gadget on top.
We have a new winner in how much can you spend on your light weight after market battery/install!
signed ... jealous (love the cut-off!)
Henry's brand new Odyssey battery blew up on Sunday at the Porsche AX ?! Left the car dead on course during his 2nd timed run. Case/top is bulged out.
- Henry'sOdyssey.jpg (250.35 KiB) Viewed 13760 times
- Steve Lepper
- Car#: 355
Mako Koiwai wrote:Henry's brand new Odyssey battery blew up on Sunday at the Porsche AX ?! Left the car dead on course during his 2nd timed run. Case/top is bulged out.
Is the angle of that shot, or did the positive terminal get over against the hold-down bracket? A short like that would sure blow one up.
Is the battery still in the front on that Porsche?
PS: Save your money... Braille batteries are just a fancy sticker on another popular maker's battery. They cross-reference directly to many standard motorcycle and commercial sizes.
Even the ones with the carbon fiber case?Steve Lepper wrote:Mako Koiwai wrote:Henry's brand new Odyssey battery blew up on Sunday at the Porsche AX ?! Left the car dead on course during his 2nd timed run. Case/top is bulged out.
- Ethan West
- Car#: 764
This thread almost makes me happy that I went with a Duralast
2003 Ford Crown Victoria Police Interceptor- CST
#764
#764
- Steve Lepper
- Car#: 355
It's a standard battery that they glue a case over. For high-temp applications, many other battery retailers (like Odyssey) use a metal jacket, and I use a moldable ceramic heat barrier panel that comes from the aircraft industry.Bob Beamesderfer wrote:Even the ones with the carbon fiber case?Steve Lepper wrote:Mako Koiwai wrote:Henry's brand new Odyssey battery blew up on Sunday at the Porsche AX ?! Left the car dead on course during his 2nd timed run. Case/top is bulged out.
Concerning Henry's blown battery:
... something to watch for.The insulation on the positive cable wore through and grounded out to the strap
