Can't find a TORX tool ...
... that is shaped like a "L" Allen Wrench. Need a TORX T-30 ... to fit in between this rear lateral link and the bottom endlink bolt. My T-30 3/8th inch "socket" plus ratchet is too wide to fit in that space. Suggestions ?
- LTfront96.jpg (76.82 KiB) Viewed 14094 times
- Thomas Smith
- Car#: 158
Re: Can't find a TORX tool ...
Are you sure you need a Torx? My mazda endlinks use a 5mm allen.
Edit: Just realized that's not a Miata.
Thomas Smith
Tom Denham
- Car#: 237
You could buy a long Torx bit and put some heat on it, bend it, quench it and have a custom tool , or you grab the vise grips and clamp your Torx bit socket and try turning it that way.
HE-y , that is the car in my Avatar.
- Eric Clements
Raise/lower the suspension so the lateral link isn't in the way.
Right ... just easier to quickly work on ramps in the paddock. I figured the end link was set to be near zero resistance at ride heights.
- Eric Clements
For quick adjustment in the paddock why would you be messing with the bottom of the endlink? The adjustable swaybar appeares to be connected to the top of the endlink.
- Bryan Fargo
Most Torx sockets will come apart- just punch out the torx bit through the bottom. The bit is a hexagon where it is pressed into the socket, so you can put the bit in the link and use a wrench to turn it.
Creating a cleaner world through alternative fuels, then destroying it with my Nova!
Upper bolt wouldn't clear the shock, at least at ride heights. We thought that removing lower bolt might help? Ur idea of jacking car up might have been the solution. Next time. Might need to then put weight back on, or jack up suspension to get bolt back in.
Sent from iPhone
Sent from iPhone
- Eric Clements
Swap the endlinks side to side so upper end removes from the inside (away from shock)?
I have a cheapie bit set from Harbor Freight that has just about everything including smaller torx's. Take the bit like Bryan said and turn (or hold) with a 1/4" wrench or a crescent or vice grips.
Having that big bit set in my trailer has come in handy for so many "oh oops how the hell.... Wait, let me try....." moments...
Along the same line, use some vice grips om the torx socket instead of the 3/8 ratchet.
- Q V
- Car#: 69
why fab when you can buy?
http://cvfsupplyco-store.stores.yahoo.n ... rense.html
something like that might work. You may be able to get cheaper searching on ebay, etc - this is just from a quick google search.
Thanks ... that's what I was looking for ... my googling didn't find that ?!
- Q V
- Car#: 69
I searched for "torx wrench" - came up under Shopping results I think; I'm guessing you were using some other keyword like tool, bit, socket, ratchet, etc.
And even better news, that link I posted above is actually cheaper than eBay! (by 6 cents, but still).
For almost the same price, thinking of getting this ratchet version ... I think it's narrow enough to fit
http://www.cvfsupplycompany.com/toto9pctobit.html
- John Prosser
Mako
You need!!!! more tools.
Check this link to a very nice Snap - On solution.
http://buy1.snapon.com/catalog/item.asp ... p_ID=19843" onclick="window.open(this.href);return false;
Of course you could drill a hole through the control arm. That should also lighten it until it folded in half.
Jason Uyeda
You could just use a pair of needle-nose (easier with Vice-Grips) on the other side of the bar/stud. With this method you only need one hand...
A good industrial hardware store will have L-shaped torx wrenches. McFadden-Dale, McMaster-Carr.
I found a set of both standard and metric, similar to the ones QV mentioned, at my local OSH in the bargain bin.Bob Beamesderfer wrote:A good industrial hardware store will have L-shaped torx wrenches. McFadden-Dale, McMaster-Carr.
Getting off my computer bound butt this morning and going to a highly recommended brick and mortar hardware store!
McFadden-Dale and Aircraft Spruce are five minutes from my house.Kurt Rahn wrote:I found a set of both standard and metric, similar to the ones QV mentioned, at my local OSH in the bargain bin.Bob Beamesderfer wrote:A good industrial hardware store will have L-shaped torx wrenches. McFadden-Dale, McMaster-Carr.
Are you taking orders ?
Delivery Charge to the Porsche event this weekend at El Toro?
I'm more expensive than the Transporter.Mako Koiwai wrote:Are you taking orders ?Delivery Charge to the Porsche event this weekend at El Toro?
- Chuck Fowler
- Club: Team Blew
- Car#: 299
NEVER OPEN THE PAKAGEBob Beamesderfer wrote:I'm more expensive than the Transporter.Mako Koiwai wrote:Are you taking orders ?Delivery Charge to the Porsche event this weekend at El Toro?
