SOLD FS: Thermal muffler
Polished stainless steel, 2.25-inch inlet/outlet. Overall 19" long and 6" in diameter; muffler body is 14.125". Weighs 7.4 lbs. Never used. Originally $115. $50.
- muffler_1.jpg (70.83 KiB) Viewed 10234 times
Last edited by Bob Beamesderfer on Sun Jan 24, 2010 8:30 am, edited 4 times in total.
Re: FS: Thermal muffler
Bob-
What's the outer diameter of the muff and the length? I'm trying to fit something under the civie for SD. And are you around on Wed AM for me to pick it up?
19" long and 6" in diameter.Steve Ekstrand wrote:Bob-
I'll be here; have work to do on the car and tire trailer.
Wow, that's long.
I'll go out and measure in a bit.
That includes the inlets and outlets. Muffler body is 14.125"Steve Ekstrand wrote:Wow, that's long.
shove
big bump
Bumpa-dee-bump. Pictures and dimensions in first post.
Bob, this is kina dumb, but do you know how much it weighs?
2017 MX-5 - #427 ???
About 9-10 lbs.Dan Shaw wrote:Bob, this is kina dumb, but do you know how much it weighs?
That's not dumb...that's the key question. You're not gonna get much more power out of a muffler. Weight reduction is the big advantage.Dan Shaw wrote:Bob, this is kina dumb, but do you know how much it weighs?
Kurt is right. This is quite a bit lighter than the stock Miata muffler, which could be used as an anchor for a small boat.Kurt Rahn wrote:That's not dumb...that's the key question. You're not gonna get much more power out of a muffler. Weight reduction is the big advantage.Dan Shaw wrote:Bob, this is kina dumb, but do you know how much it weighs?
I've been at the interwebs recently trying to lock in an exhaust upgrade for that purpose: losing weight. Best I've found is the Roadstersport at 12.4 lbs, but it's $300. I'm cheep like that and don't wanna pay that much for something that well-made and light weight.
Honestly though I don't really feel like spending that much when I'm pretty sure it could be done without so much flash for less dinero.
Let me make sure I can pay before I commit to it. if someone else comes along let it go, but if by my next check things work out and it's still around I'll pick it up at the feb. event.
On the scale at the UPS store, it's 7.4 pounds.
Bumpski
Bob, you want me to PP you the money? or do you want cash/check at the next event? Let me know, lets do this!
random ?...would you happen to know someone who could also weld this thing up? maybe cut a new flange, too? would prefer to keep the stock canister intact.
Thanks.
Thanks.
John Coffey at Beta Motorsports can do that kind of work. How soon you get it depends on how busy he is, being a one-man shop.Dan Shaw wrote:random ?...would you happen to know someone who could also weld this thing up? maybe cut a new flange, too? would prefer to keep the stock canister intact.
Thanks.
PayPal works fine. r s b 95 at att dot net
Sent. I padded it some for the % Paypal takes out. but ya. If you can bring it to the next event that would be great!
Thanks! I'll get on the horn with Beta.
Thanks! Will bring to next event. What class are you running these days?Dan Shaw wrote:Sent. I padded it some for the % Paypal takes out. but ya. If you can bring it to the next event that would be great!
np, SK2, c stock.Bob Beamesderfer wrote:Thanks! Will bring to next event. What class are you running these days?Dan Shaw wrote:Sent. I padded it some for the % Paypal takes out. but ya. If you can bring it to the next event that would be great!
muffler by itself weighs about 7.5 lbs; with a 90-degree section and a turndown and a couple of flanges it should right around 12.Dan Shaw wrote:np, SK2, c stock. Figure the last thing I can do within class limits is the exhaust. Can't do the midpipe since it's welded but I figure at the axle could at least shave some weight. 12/13lbs is much better than 24/25.Bob Beamesderfer wrote:Thanks! Will bring to next event. What class are you running these days?Dan Shaw wrote:Sent. I padded it some for the % Paypal takes out. but ya. If you can bring it to the next event that would be great!
I'll drop by the event around 10 on Sunday; I'll be in my Toyota Pickup, aka, the Red Rat.
