During my run with Tom Berry, he commented on the size tires and wheels I should run on my 1990 C4 Corvette. Apparently he campaigned one very successfully some years ago. I have tired PMing however imagine he and the family are very busy getting the Evo rebuilt in time for the pro solo event. Any way this is open. I have a competition lowered 1990 C4 corvette. Am currently running 17x9.5 inch rims at all 4 corners shod with Kumho SPTs in 275 / 40 / 17. I am considering two options. One is to go to a larger wheel and tire on the rear of the car, the other is to go all the way and buy a race set with V710's.
I understand the stickier tires might be more fun, or they might just mask my driving deficiencies. I say this only because I know there is a lot of potential in the car with the stock set up. My best was a 93.2, George ran a relaxed (well teaching) 84.0. Tom ran a relaxed (well teaching) 80.4 after I had raised the rear tire pressure to 36 lbs (which appears to be the wrong direction) ergo I have at least 13 seconds of improvement available without doing a thing to the car. I do think larger rears would help tame the cars torque and balance up better. At this point I don't want to do anything that would move me out of BSP. I also don't want to do anything that will harm the body work. If I go with a larger rear wheel street tire set up I would likely just leave it on the car and save my current nearly new rears as replacement fronts.
I need to say I am not contending for championships, just trying to have fun and become a better driver. I was 16th at El Toro in the novice group, I am not delusional enough to believe I am going to buy magic equipment or tires that put me at #1 and win me a trophy. My goal at any event is to be better than the last event, and to improve each run with hopefully no DNF's. Better right now for me would be looking farther ahead, without suddenly getting surprised by the present.
Thanks for comments.
C4 Corvette Tire & Rim Size
Arthur Grant
- Car#: 314
Re: C4 Corvette Tire & Rim Size
Take some time and work on the driver first. I'd suggest not making any changes yet until you determine where you fit in and what class you want to run. Then, build your car to the rules of that class. Don't put on "R" comps until you can handle street tires efficiently. Just my 2 cents.
-George
-George
+1George Schilling wrote:Take some time and work on the driver first. I'd suggest not making any changes yet until you determine where you fit in and what class you want to run. Then, build your car to the rules of that class. Don't put on "R" comps until you can handle street tires efficiently. Just my 2 cents.
-George
- Steve Towers
- Car#: 87
Giovanni Jaramillo
That's EXACTLY what they'll do...mask the deficiencies like a "cloaking device" on a starship!Arthur Grant wrote:I understand the stickier tires might be more fun, or they might just mask my driving deficiencies.
Arthur Grant
- Car#: 314
Since my front and rears are the same size, is worth going to wider rear tires. The ECSTAs aren't expensive and either are the wheels. Would still be the same street tire all around just not the same size at all four corners. George et all. Thank you very much for responding. Your input is highly valued.
What are you trying to accomplish with the larger rear tire size? Other people went 10 seconds faster than you on the tires you currently have. I'd leave the tires alone and try to match their times. Get instructors at practices and championships. Get seat time.Arthur Grant wrote:Since my front and rears are the same size, is worth going to wider rear tires. The ECSTAs aren't expensive and either are the wheels. Would still be the same street tire all around just not the same size at all four corners. George et all. Thank you very much for responding. Your input is highly valued.
EVo school FTW. +4 on improving your skills first. It's almost free and while you're setting up options you can make the most of the tire you have left. Get In for more practices and ask questions on better line options, taking slaloms, etc. Evo school improved my drivig tremendously. I ran times in the morning, and during our class it rained pretty hard. By the end of theday I was beating my dry times in te wet. That's at least a 3 second improvement.
2017 MX-5 - #427 ???
