I have an assorted set of reusable vinyl numbers, and given that the Coxster is made of steel everywhere, I can use magnetic numbers.
My idea is to place the reusable vinyl numbers on a white (or black) magnetic sheet and then cut the number, so I will have magnetic numbers instead.
Any walk-in store that sells quality magnetic sheets?
Rad_ Delgado_
- Car#: 512
Nicole Wong
- Car#: 46
Re: Any walk-in store that sells quality magnetic sheets?
Not walk-in but you can get it pretty quick.
I use this... http://www.mcmaster.com/#5756k35" onclick="window.open(this.href);return false; item# 5756K35
Other than that, I know Michaels sells sheets, but they didn't work very well.
http://www.mclogan.com/shop/contact_us.php" onclick="window.open(this.href);return false;
Nicole Wong
- Car#: 46
Hey thanks, didn't know this place was so close to us!Rick Brown wrote:http://www.mclogan.com/shop/contact_us.php
Rad_ Delgado_
- Car#: 512
Great info. Thanks a lot !!!
We used Kinko's once to buy mag material at the last moment ... it was a bit expensive
Not walk in... says who?Nicole Nagler wrote:Not walk-in but you can get it pretty quick.
I pick my magnetic sheeting up at will call in Santa Fe Springs. From 1st hand experience, order SEVERAL hours in advance, or expect to wait 2 hours on site. Limited employees can pull and pack the product as it's a "hazardous material". You will also have to sign a release that you will not take it, or ship it, on board an airplane due to it's "hazardous material" designation.
