White powder on the valves and turbo – E85
Christos Adam
Car#: 550
Post by Christos Adam »
After the last pro solo event in El-Toro I decided to remove my turbo since I had a huge an air leak between the exhaust manifold and the turbo.
To my surprise I noticed the turbo and the valves had a white coating on them.
I wasn’t expecting to see carbon deposits since I run E85 but what is these white stuff?
Car#: 194
Re: White powder on the valves and turbo – E85
Post by Jonathan Lugod »
A "good" exhaust valve that is sealing and holding compression will usually have white or tan colored ash deposits on it.
Christos Adam
Car#: 550
Jonathan Lugod wrote:A "good" exhaust valve that is sealing and holding compression will usually have white or tan colored ash deposits on it.
Thanks Jonathan, good to know that...
Doesn't White, as opposed to light tan, indicate a bit hot?
My WRX Turbo ... 95 octane mix:
Casey Brier
Car#: 806
Post by Casey Brier »
I've always thought that meant "too lean"..... but thats on normal gasoline. I dont knwow if E-85 is the same?
Casey Brier wrote:I've always thought that meant "too lean"..... but thats on normal gasoline. I dont knwow if E-85 is the same?
It did when reading plugs, but I wonder if because this is outside of the combustion chamber whether it means the same thing. :?:
