FS: USED/NEW Race Springs
Hypercoil Race Springs
8" x 2.5" x 700lbs QTY 2 - USED
8" x 2.5" x 550lbs QTY 4 - USED
8" x 2.5" x 500lbs QTY 2 - USED
8" x 2.25" x 350lbs QTY 2 - USED
7" x 2.25" x 1000lbs QTY 1 - USED
6" x 2.25" x 700lbs QTY 1 - USED
7" x 2.25" x 250lbs QTY 1 - USED
8" x 2.5" 800lbs QTY 2 - New
8" x 2.5" 600lbs QTY 4 - New
7" x 2.25" 550lbs QTY 1 - Used
5" x 2.25" 400lbs QTY 2 - Used
4" x 2.25" 400lbs QTY 2 - New
6" x 2.25" 350lbs QTY 2 - New
5" x 2" 300lbs QTY 1 - New
Eibach Race SPrings
8" x 2.25" x 700lbs Qty 4 - USED
6" x 2.5" x 700lbs QTY 1 - USED
6" x 2.25" 1500lbs QTY 2 - Used
8" x 2.25" 660lbs QTY 2 - Used
8" x 2.25" 375lbs QTY 1 - Used
9" x 2.25" 350lbs QTY 2 - Used
H&R Race Springs
6" x 2.5" x 900lbs QTY 1 - USED
8" x 2.5" x 800lbs QTY 2 - NEW
I will have more posted later. Each spring is $40.00 + tax (9.75%) if you live in CA.
Eibach Race SPrings
H&R Race Springs
- Car#: 194
Re: FS: USED/NEW Race Springs
hmmm those 1000lb springs are taunting me to use up front.
Front not back? I thought the usual Civic setup was stiffen the back so the car will rotate.Jonathan Lugod wrote:hmmm those 1000lb springs are taunting me to use up front.
will 2.5" springs rattle on my 60mm perches?
- Michael Palero
- Car#: 18
Jeff just told me they've all been sold.
@Daniel I used 2.5" on my old KW 60mm perches. They worked fine as is. But it was easy to build up the perches by wrapping some tape around the perch. I did that. And when I switched out perches I tried it without and didn't notice a difference. YMMV.
daniel, ive also used 2.5" springs on my 2.25" springs, they will not rattle, just have to make sure they sit on the upper spring perch properly when you let it down. The clearance isnt as great from 60mm -> 2.5" anyways.Daniel Yeung wrote:will 2.5" springs rattle on my 60mm perches?
update spring list.
Will started to salivate when you listed the 6" 1500lb springs.
Thanks for the advice. I'm gonna throw 'em on my KWs!!Steve Ekstrand wrote:@Daniel I used 2.5" on my old KW 60mm perches. They worked fine as is. But it was easy to build up the perches by wrapping some tape around the perch. I did that. And when I switched out perches I tried it without and didn't notice a difference. YMMV.
Jeff: can you bring the 8"x2.5"x550lbs (all four) to the next auto-x? Thanks!!
6.7Hz FTW!Steve Ekstrand wrote:Will started to salivate when you listed the 6" 1500lb springs.
Will Kalman wrote:6.7Hz FTW!Steve Ekstrand wrote:Will started to salivate when you listed the 6" 1500lb springs.![]()
Interesting... I only show ~3.2hz in the front... Unless this is a joke. Maybe you are talking about your escort
You forgot the 2.0938 multiplier.Jeff Wong wrote:Will Kalman wrote:6.7Hz FTW!Steve Ekstrand wrote:Will started to salivate when you listed the 6" 1500lb springs.![]()
Interesting... I only show ~3.2hz in the front... Unless this is a joke. Maybe you are talking about your escort![]()
@Jeff Its for the RX8 we're building.
You do the math and let me know what you come up withKJ Christopher wrote:You forgot the 2.0938 multiplier.
Sprung Weight = ~580lbs
Wheel Rate = ~614lb/inch
- Car#: 194
hmmmm i can use those up front! then maybe ill try no front bar
Yes, big improbable numbers make the joke funnier.Jeff Wong wrote:Interesting... I only show ~3.2hz in the front... Unless this is a joke. Maybe you are talking about your escort![]()
(And the Escort was just a shade under 3Hz in front not counting sway bar - you don't want to know the rear number, which is typically absurd in FWD applications).
Jeff Wong wrote:You do the math and let me know what you come up withKJ Christopher wrote:You forgot the 2.0938 multiplier.
KJ Christopher wrote:Jeff Wong wrote:You do the math and let me know what you come up withKJ Christopher wrote:You forgot the 2.0938 multiplier.
Wheel Rate = ~614lb/inchyou're funny sometimes....
- Steve Collins
- Car#: 799
Of course the frequency drops when you add damping so you'll probably want to set your shocks full soft to maximize the effect of the stiffer springs...
On second thought, I've decided that I'm not going to revalve my Kws, so no need to bring the springs this wknd.Daniel Yeung wrote:Thanks for the advice. I'm gonna throw 'em on my KWs!!Steve Ekstrand wrote:@Daniel I used 2.5" on my old KW 60mm perches. They worked fine as is. But it was easy to build up the perches by wrapping some tape around the perch. I did that. And when I switched out perches I tried it without and didn't notice a difference. YMMV.
