New to forum, new to autocross, need suspension advice
Tim Doran
Post by Tim Doran »
I have a 68 Porsche 912, looking to start racing it after I finish with the suspension. Next project is rear bushings, I have a set of rubber bushings that I was going to use, because at the time this was going to be a street daily driver, would polygraphite bushings be that much better? The car has no swaybars, first mod? Whats a good choice for shocks, was leaning towards koni street shocks, but... ?
Thanks, Tim
Steve Towers
Car#: 87
Re: New to forum, new to autocross, need suspension advice
Post by Steve Towers »
Tim,
Possibly better to post a Porsche question on http://www.pcaocr.org" onclick="window.open(this.href);return false;. The Orange Coast Region of Porsche Club of America.
Robert Puertas
Car#: 44
Post by Robert Puertas »
Tim,
The mods you make will determine what class you run in.
The 912 runs in the following classes:
Stock = HS
Street Touring = STS
Street Prepared = FSP
The aftermarket bushings and bars would not be legal for stock. You'd also have to run on stock-sized wheels.
STS and SP allow those mods, plus alot more.
There are certainly some capable Porsche drivers on here, too. Have you researched what class you want to be in? You need to be careful before making any mods as sometimes very simple things can bump you into a class you don't want to be in.
Tim Doran
Post by Tim Doran »
Hmmm, more food for thought.
Already have a big bore kit, webers, cam and exhaust, so stock is probably out of the question... :shock:
I guess more research is in order.
Thanks, Tim
Randy Chase
Car#: 98
Post by Randy Chase »
CSM makes things easier
Tim: we have a couple of Run What U Brung classes, basically anything that can still be licensed for the street. California Street Mod, is that class, running on DOT R tires. CST = same but with Street Tires w/ a minimum of 140 wear factor. There are some very specific tires to use. We can advise ...
Doug Teulie
Car#: 99
Post by Doug Teulie »
Tim Doran wrote:Hmmm, more food for thought.
Thanks, Tim
Cam and possibly the bore puts you in SM, CST(?) or CSM.
Doug T
