Places to have rotors turned?
- Vincent Wong
- Car#: 107
Anyone knows where is a good place (with fast turnaround time) to have the brake rotors turned? Hopefully somewhere close to West Covina. Thanks.
Re: Places to have rotors turned?
O'reilly Auto Parts, there everywhere. $15 ea. Usually a 1 hr turn around.Vincent Wong wrote:Anyone knows where is a good place (with fast turnaround time) to have the brake rotors turned? Hopefully somewhere close to West Covina. Thanks.
Couple of thoughts on turning rotors...
Many (most) newer sports type cars use relatively light rotors, which means less material to work with...many just can't be turned and those that theoretically can end up very compromised in their ability to dissapate heat with the loss of material mass.
In some instances, like my old Z06, new rotors from a place like Rock Auto were only about $10/corner more than turning.
If you think you need rotors because of shuddering or vibration under braking, you might try using a hand drill and a Scotch Brite attachment and cleaning up the brake pad transfer layer on your current rotors, then re-bed. Rotors don't actually warp, they build up uneven transfer layer...most commonly.
agree ... better to just buy inexpensive replacements. The Spec Miata racers just buy the cheapest ones that they can find at automotive chains
- Michael Sullivan
- Car#: 357
Ed's Auto Parts... Grand Ave & Covina Blvd
Last edited by Michael Sullivan on Fri Apr 22, 2011 11:04 am, edited 1 time in total.
Michael Sullivan
Vincent doesn't own a lotus, he'll be fine turning them. O'riley will let you know if they're too thin/worn. Before you comit to turning though, check how much OE replacements are.
Always wondered how critical turning is. Once a pad is bedded, wouldn't all those hills and valleys actually increase the surface area?
- Vincent Wong
- Car#: 107
I've checked the OE replacements.Jayson Woodruff wrote:Vincent doesn't own a lotus, he'll be fine turning them. O'riley will let you know if they're too thin/worn. Before you comit to turning though, check how much OE replacements are.
BMW = $538
Zimmermann = $313
Centric (from Tire Rack) = $282 (but I might be able to get them cheaper from my source)
turning rotors at Ed's (thanks Mike Sullivan) = $40 for the set
I'm not sure, but I've read from a few sources that the Carbotech race pads need either new or resurfaced rotors to work properly, unless the previous pads used were also Carbotech.Rick Brown wrote:Always wondered how critical turning is. Once a pad is bedded, wouldn't all those hills and valleys actually increase the surface area?
Just lightly sand them yourself ... that's what I did when we went to carbotechs on Karen's track Miata. $40 isn't bad, but if you're going to have to pull the rotor's you could also just do the sanding yourself.
One sees the WRC rally mechanics hand sanding rotors during their "pit stops."
Which carbotechs are you going to? We're using 8's ... the non-ABS Spec Miata's typically use 10's
- Vincent Wong
- Car#: 107
XP12 front, XP10 rear; that's what Emilio recommends.Mako to wrote:Which carbotechs are you going to? We're using 8's ... the non-ABS Spec Miata's typically use 10's
We just take the 335 to the Dealer and they do the brakes under the maintenance agreement...
12/10 ... well your BMW is heavy ... let us know how they work on the street?!
- Vincent Wong
- Car#: 107
How long did your OEM brakes last? I'm just under 21k, and the service message for the rear brake pads has been on for weeks. Now the service message for brake fluid is on.Steve Ekstrand wrote:We just take the 335 to the Dealer and they do the brakes under the maintenance agreement...
I'm upgrading the brakes for track use.
Have you been tracking the Bimmer with oem brake components?
- Vincent Wong
- Car#: 107
So far,Mako to wrote:Have you been tracking the Bimmer with oem brake components?
Spring Mountain: 1x
AutoClub Speedway (Roval): 1x
SOW: 3x
The OEM brakes at SOW seem ok. At ACS, after a few 130-30 braking, the OEM brakes faded a bit.
Here's a video of my best lap at SOW.
http://www.youtube.com/watch?v=lZeUy37qfFw
You're going to love the Carbotechs! Are you getting steel braided lines also? SpeedBleeders would be nice.
Please email me about Spring Mountain. That's where our next Miata Challenge event is.
- Vincent Wong
- Car#: 107
Yeah...Goodridge SS lines, and ATE Super Blue brake fluid.Mako to wrote:You're going to love the Carbotechs! Are you getting steel braided lines also? SpeedBleeders would be nice.
What are those things in your Profile Pix?
I think we had pads changed at about 28k. I have this vague memory that they replaced rotors on one at least one end.
- Vincent Wong
- Car#: 107
Audi and BMW keys/key fobs.Mako to wrote:What are those things in your Profile Pix?
? ... are they also smart phones/cameras ?
If you're going to a higher heat range pad and doing track days, the last thing I'd want to do is let some O'Reilly type "shop" take material off my rotors...can you say "radial cracking"?
For kind of a "Cliff's Notes" version of a bunch of brake science, the Stoptech web site has a number of white papers that are really good, if anyone's interested.
btw, I really like Carbotech pads and, you're right, they sometimes have a problem scraping the prior transfer layer to bed, but I don't think that will be problem if you were running oem pads. It happens more when going from one high heat range pad (particularly Hawks) to the Carbotechs, in my experience. The XP12/10 combo is really aggressive, if you plan on doing any street driving. Not only will they squeal and grind, they also may accelerate rotor wear.
- Car#: 14
Huh. I always thought they were phasers.Vincent Wong wrote:Audi and BMW keys/key fobs.Mako to wrote:What are those things in your Profile Pix?
