![Image](http://i257.photobucket.com/albums/hh240/oinojo/207933_10150266624169338_551884337_9248572_8028880_n.jpg)
![Image](http://i257.photobucket.com/albums/hh240/oinojo/206975_10150269857769338_551884337_9277244_6354766_n.jpg)
2009 - San Diego ST Regional Champion
2010 - SCCA San Diego National Tour - 5th Place Trophy
2010 - SCCA El Toro Pro Solo - 2nd Place Trophy
2011 - SCCA San Diego National Tour - 1st Place
2011 - SCCA El Toro Pro Solo - 1st Place
2011 - SCCA Solo National Championships - 3rd Place
Chassis Mileage approximately 206,xxx miles
Engine Rebuilt at 142,xxx miles w/ documentation
Engine:
Rebuilt D16a6 Block
Rebuilt D16 (PM3) Cylinder Head
Standard bore pistons
OEM Honda Bearings
OEM Honda Water pump
OEM Honda Oil Pump
Greddy 4-2-1 Header
Magnaflow hi-flow 2.25 cat
Custom magnaflow lightweight exhaust
Custom Tuned ECU w/ 7800rpm limiter - 4100rpm launch control
Front/rear Polyurethane Motor Mount inserts, Side mounts 3M Windoweld injected
Custom 3"x19" Short Ram intake w/ BPi Velocity Stack and K&N filter
Lightweight Battery Plus Battery (5lbs)
Suspension: Custom Koni 8041's
700lbs Hyperco Springs Front
700lbs Eibach Rear
Ingalls Rear Upper Camber Arm
ProParts USA Custom Front Upper Control Arm
Energy Suspension Polyurethane Bushings
OEM Honda Rear Trailing Arm Bushing
Custom Front Upper Control Arm Delrin Bushings (currently off car)
Ground Control Extended Top Hats (Front)
Custom Built Rear Sway Bar - .250 wall thickness, 43inches long w/ 4-5-6 inch length arms, adjustable spherical endlinks.
Brakes:
Axxis Ultimate Deluxe Front Pads
NAPA Special Front Rotors
PepBoys Rear Drums
Centric Rear Shoes
Goodridge Stainless Steel Brake Lines
Interior: Stock
Sparco 350mm Steering Wheel
Sparco Junior Speed Driver Seat
F1Spec Passenger Seat (needs upholstery)
Custom Seat Brackets to Stock Sliders
Exterior: Stock
1 extra set of front fender liners (common to break off car)
Detail work done by co-driver and Meguiars specialist Michael Palero
Wheels:
(4) 15x7.5 TRmotorsport w/ 195/50R15 Toyo R1Rs
(4) 15x7.5 Rota Slipstream w/ 195/50R15 Toyo R1Rs
(4) 14x5.5 Steelies w/ 185/60R14 Dunlop Z1 Star Specs
I built the car with National Competition intended. I will be driving this car until the 2011 National Championship in Lincoln, Nebraska then i will release this car. So I am putting this car on SCCA forums to feel out the buyers. I have driven this car for the past 4.5 years and would love to see this car continue its successful record in the hands of a fellow autocrosser.
Videos:
http://www.youtube.com/watch?v=7HbT0xlgOgA
El Toro Marine Base - Practice
http://www.youtube.com/watch?v=acgW0duMJLM
I am proud to say that i have the suspension setup spot on for both low grip and high grip lots. I make no changes when racing at different venues and allows the driver one less variable to worry about. Any additional notes about setup will be transferred to the new owner.
Price: $6000 obo
I may have missed a few points and if there are any further questions you can ask me on this thread or PM.
