Sebastian Rios wrote:Steve Lepper wrote:
I doubt you would ever have a problem locally. In a divisional, maybe... at Nationals or a Pro, definitely.
Oh, and good luck getting it smogged.
So to be SCCA Stock legal, everything must be changed out including the ECU, and wiring harness?
For smog, do you say good luck because it's visually obvious or because you may run into a smog shop that is a stickler, it should still pass the sniffer and not throw CELs right?
Yes. Regarding SCCA, a Cal-spec car has a different wire harness, and since the two O2 plugs are plainly visible under the hood, it would be an easy protest. Can't legally modify it, so you'd have to swap it. You also need the Federal emission sticker: see below for more about that...
Regarding smog, there are a couple of problems.
First, as was mentioned earlier, you need the correct, 49-state smog sticker to go with the conversion. Problem is, in order to purchase these you have to provide the vehicle's VIN, and the dealer won't sell you one that is not for your car. One of the reasons this is done is to prevent exactly the kind of emission system conversion (they call it "tampering") you're trying to accomplish. Maybe you could buy them more easlily through Motorsports... I haven't yet tried that route as I had another way around that issue.
When you go for a smog check, you converted car will already be in the CARB system with the VIN listed as a Cal-spec car, so when you show up for a Smog Check and the tech tries to enter your car as Federal, you will fail. Doesn't matter what the tailpipe result is, because you won't even get that far. Only way around this is to know a friendly tech that will look the other way and still enter the car as Cal-spec, or make it a trailer queen that never needs plates.
