June Super Regional Registration Open-RUN ORDER ADDED
Daryl Lane
Re: June Super Regional Registration Open
Post by Daryl Lane »
OK thank you Just called MREG and Ann said only one charge my bad - thanks for clarifying this for me KJ
I don't think it changes anything as far as workers, but Max should be listed as a novice (RTF DS). I guess I can fix that at registration.
Kurt Rahn wrote:I don't think it changes anything as far as workers, but Max should be listed as a novice (RTF DS). I guess I can fix that at registration.
Not a valid class listing. Either he's running in Novice/DSK (D Stock on Street Tires) or RTF/DS. If his normal regional class is Novice, he'll be reclassed after the event for local results.
Ahhhh. That's the problem. As long as he'll be automatically reclassed, then he's fine as is
Don Green
Post by Don Green »
Sorry to be a bother, but I need to make a class change. I will not be driving STC. Instead I would like to drive Historic 2 in my '85 Honda CRX, black, still number 29. Who do I contact, or is this enough? Thanks, Don
Don Green wrote:Sorry to be a bother, but I need to make a class change. I will not be driving STC. Instead I would like to drive Historic 2 in my '85 Honda CRX, black, still number 29. Who do I contact, or is this enough? Thanks, Don
Reg is still open so you can edit your entry. Just log in and go to the event dashboard, click update registration and make the changes.
Post by KJ Christopher »
Actually, we changed over the weekend to not allow changes by the user so we can track them. I'll update your entry.
David Barrish
Car#: 58
Post by David Barrish »
Don,
Are you going to run the Falkins?
David
Arthur Grant
Club: TCC
Car#: 314
Post by Arthur Grant »
Did I miss the run order somewhere?
Arthur Grant wrote:Did I miss the run order somewhere?
No.
Kevin Pao
Re: June Super Regional Registration Open-RUN ORDER ADDED
Post by Kevin Pao »
Will the run order be the same for both days?
Kevin Pao wrote:Will the run order be the same for both days?
Yes.
Robert Baltazar
Car#: 591
Post by Robert Baltazar »
I have question on Changing my sons kart # to 192. He has a co driver now. Is it to late to change numbers?
Last edited by Robert Baltazar on Wed Jun 13, 2012 8:59 pm, edited 1 time in total.
1991 turbo RX7 12.4 111.18 mph http://www.youtube.com/watch?v=WmeEuCbcNUg" onclick="window.open(this.href);return false;
Cal speedway 1.55
http://www.youtube.com/watch?v=3hhunwtiGLk" onclick="window.open(this.href);return false;
Robert Baltazar wrote:I have question on Changing my sons kart # to 192. He has a co driver now. Is it to late to change numbers?
No problem. Who's the co-driver?
Robert Baltazar
Car#: 591
The co driver is bejion yeoh...
Cal speedway 1.55
Robert Baltazar wrote:The co driver is bejion yeoh...
I don't see Bejion as registered and reg is closed. Need Stephen or someone to contact me.
Robert Baltazar
Car#: 591
Hey Rick, I guess KJ is talking with Stephen. I quess I'll find out what's going on later this afternoon.
Cal speedway 1.55
Ryan Young
Car#: 510
Post by Ryan Young »
Hey Rick,
I'm running Novice/DSK this weekend and just wanted to double check my run/work group. I'm thinking that I am with the DS group (running Heat 5/working Heat 2) - is that correct?
Thanks!
Ryan Young
Solo Noob
#510 RTA, 2011 Subaru WRX
Ryan Young wrote:Hey Rick,
Thanks!
Since you're DSK, I'm pretty sure you'd be with RTA, but DS and RTA run/work the same group, so it's all good.
Thanks!
Yes, you have been re-classed to RTA/DS for the event. You'll be put back in Novice for local 1 day results and points. This is true for all Novices in the event - you have been re-classed into the appropriate regular class, RT if you are on street tires, otherwise your normal base class.
Ryan Young
Car#: 510
Excellent, thanks guys! In that case, what magnets/class letters should I put on my car?
Ryan Young
Solo Noob
Tom Denham
Car#: 237
Post by Tom Denham »
Ryan Young wrote:Excellent, thanks guys! In that case, what magnets/class letters should I put on my car?
R T A
Ryan Young
Car#: 510
Got it - thanks again!
Ryan Young
Solo Noob
Tom Denham
Car#: 237
Ryan Young wrote:Got it - thanks again!
Do you have a set??? Jay Woodruff make good numbers and letters, It is a little late probably for this event.
I have a extra set in red, isn't your #'s red you can borrow them for this weekend if need be.
Let me know so i can pack them .
