Stock Class Question: Air Oil Separators
- Sean Fenstermacher
- Car#: 81
Quick question for "those who know":
I understand that oil catch cans are allowed in Stock class, but would an air/oil separator be allowed (as an OCC)?
I am eyeing this unit from Crawford Performance (pricey though...):
http://store.crawfordperformance.com/store/products/652" onclick="window.open(this.href);return false;
The system plumbing is the same as a Stock legas OCC. Closed system.
- Car#: 194
Re: Stock Class Question: Air Oil Separators
yes, as long as it stays a closed system it is okay.
- Car#: 81
Awesome! Thanks "King of Fastrack"! LOL
- John Coffey
- Car#: 250
If I was a protest dick I would throw paper on that in a heartbeat (unless there's a specific mention of air/oil separator in a FastTrack). Its not a catch tank, its an air/oil separator and does confer a performance advantage (less oil in the intake). Be ready to defend it at a NT or the Nationals.
G. The installation of water expansion tanks is allowed. The installation of oil catch tanks is allowed provided the PCV system is not altered.
Morgan Trotter
- Car#: 61
The rule book specifically allows you to install an oil catch tank as long as you keep the system as it was. Closed.
Tom Denham
- Car#: 237
pOtatoe, pAtatoe, tOmatoe, tAmatoe.
- John Coffey
- Car#: 250
Again, check to see if any protest dicks are running in class Sean (they do exist in the Solo world). Be ready to back up your mod.
- Car#: 81
Thanks for the warning, John!
I think I'll hop on the SCCA website and search for the contact info to inquire about a ruling.
Anyone have any tips on sending in such requests? Maybe I should ask Crawford for a plumbing diagram.
Senseless work for no performance gain and a lighter wallet!! I guess this is the norm for running in a "real" class...
- Car#: 81
To get a ruling on this would I need to submit a letter to the SEB?
http://www.sebscca.com/index.php" onclick="window.open(this.href);return false;
- Eric Clements
If no performance gain why would you want to install it?Sean Fenstermacher wrote:Senseless work for no performance gain and a lighter wallet!!.
- Car#: 194
some cars consume an excess amount of oil from autocross. I know my civic used to gobble up a lot of oil during a run (at the right oil level) and smoke would poor out the back. Seb Rio's car does it on the regular nowadays.
Mine is known for the oil vapor building up on the valves. Detergents run thru the fuel system aren't effective since it's direct injection. OCC is the only solution.Jonathan Lugod wrote:some cars consume an excess amount of oil from autocross. I know my civic used to gobble up a lot of oil during a run (at the right oil level) and smoke would poor out the back. Seb Rio's car does it on the regular nowadays.
But a catch-can would help with that, correct? Why would you spend more money on an air-oil separator if it only did the exact same thing?Jonathan Lugod wrote:some cars consume an excess amount of oil from autocross. I know my civic used to gobble up a lot of oil during a run (at the right oil level) and smoke would poor out the back. Seb Rio's car does it on the regular nowadays.
- Car#: 81
Because race car! LOL
It seems that their A/O separator unit is a bit more efficient and doesn't require any maintenance.
Also, they have a turn-key for the FR-S with all the mounting hardware.
Currently no OCC's out there offer such a turn-key kit other than Cusco and their unit is not baffled (supposedly if not baffled then meaningless).
Tom Denham
- Car#: 237
The WRX comes with one from the factory! It's called an intercooler
:barf:
