Doug Teulie wrote:Yes wheel dia and tire selection can make or brake you.
13s have no options for good street tires unless you have them custom made or import them (and you can't use non DOT).
13s have several R-comps. Cars with 13s really need to run on race tires.
14s have one size (185) and one tire that fits most cars. 14s have one 195 that fits the BMW 325 and is close for all the other cars (Honda, Toyota, VW, and mazda miata) that have 14s.
14s have a few R-comps.
15s have many options in both DOT street and DOT R.
16s have a few usable street tires options but 17s have more. Some models of cars came with 16s and then 17s. 17s have the advantage. Because Stock will not allow the change from year to year many cars are stuck using 16s when the next model year had 17s. In the case of the AP1 S2000 the offset is difficult to get in a 17 that is the same width and stagger as the 16 so it would be better to be able to just use the wider OEM 17 that came on the 2004+ AP2. If the AP2 wheel is not an option on the AP2 then $$$$$ custom wheels are the way to go.
17s have many options in both DOT street and DOT R.
I don't know about 18s, 19s, 20s, 22s, and up.
If this is really the reason, then why don't they just tackle the issue head on and allow everyone to play with a good tires?
The whole point is to go fast and have fun, right?
Vehicles Equipped with 13",14" = allow to up size to 15"
Vehicles Equipped with 17/18" = no allowance
Vehicles Equipped with 16" = allow up size to 17" (except Leonard!! LOL)
Vehicles Equipped with 19s = allow downsize 18"
Vehicles Equipped with +19s = allow downsize to 19"
Toss in an acceptable allowance for wheel width adjustment (+/-0.5" or 1") to open up the selection of off the shelf aftermarket wheels.
I think a realistic push in a one direction would better allow for more even and consistant classing for fully prepped cars.
Doesn't anyone else think that allowing for wheel changes in both directions kinda opens the door for having to very course dependent set-ups or potential inconsistencies with regards to class balance due to gearing/tire/wheel choice?
One of the things that appeal most about RT Stock (Street) class to me is the simplicity and lower level of investment.
The new camber rules complicate things, but I see are needed for McStrut cars. There should be a limit on how much neg. camber is allowed though, IMO.
The 2 sway bar thing is interesting....opens the door for BBSS (
Big-Bar-Soft-Spring) tuning!! (just like NASCAR!!)
