Bill Martin wrote:Ed Holley wrote:As described in the ad, particularly the engine swap, would that be legal in CST or....?
Isn't CST run-whatcha-brung with the only restrictions being street legal stuff like wipers & lights, and street tires?
If I actually have to CA smog and register, then I won't do it.
Bill - here is the exact rule
CALIFORNIA STREET TOURING (CST): Vehicles eligible for CST must comply with the rules of CSM, with the exception that all of the tires mounted on the car must have a TREADWEAR number of 140 or higher molded by the manufacturer on the sidewall.
CALIFORNIA STREET MODIFIED (CSM):
Vehicles eligible for CSM must be capable of being licensed for street use in California, shall be run on DOT approved tires and must meet all SCCA Solo Safety requirements.
It doesn't say it has to be registered in California, just capable of being registered.  I'm not sure how one gets around California Smog but then basically every ST car would potentially have the same problem according to SCCA rules and CAT requirements.
