June Super Regional Registration Open-RUN ORDER ADDED
- Daryl Lane
Re: June Super Regional Registration Open
OK thank you Just called MREG and Ann said only one charge my bad - thanks for clarifying this for me KJ
I don't think it changes anything as far as workers, but Max should be listed as a novice (RTF DS). I guess I can fix that at registration.
Not a valid class listing. Either he's running in Novice/DSK (D Stock on Street Tires) or RTF/DS. If his normal regional class is Novice, he'll be reclassed after the event for local results.Kurt Rahn wrote:I don't think it changes anything as far as workers, but Max should be listed as a novice (RTF DS). I guess I can fix that at registration.
Ahhhh. That's the problem. As long as he'll be automatically reclassed, then he's fine as isRick Brown wrote:Not a valid class listing. Either he's running in Novice/DSK (D Stock on Street Tires) or RTF/DS. If his normal regional class is Novice, he'll be reclassed after the event for local results.Kurt Rahn wrote:I don't think it changes anything as far as workers, but Max should be listed as a novice (RTF DS). I guess I can fix that at registration.
Sorry to be a bother, but I need to make a class change. I will not be driving STC. Instead I would like to drive Historic 2 in my '85 Honda CRX, black, still number 29. Who do I contact, or is this enough? Thanks, Don
Reg is still open so you can edit your entry. Just log in and go to the event dashboard, click update registration and make the changes.Don Green wrote:Sorry to be a bother, but I need to make a class change. I will not be driving STC. Instead I would like to drive Historic 2 in my '85 Honda CRX, black, still number 29. Who do I contact, or is this enough? Thanks, Don
Actually, we changed over the weekend to not allow changes by the user so we can track them. I'll update your entry.Rick Brown wrote:Reg is still open so you can edit your entry. Just log in and go to the event dashboard, click update registration and make the changes.Don Green wrote:Sorry to be a bother, but I need to make a class change. I will not be driving STC. Instead I would like to drive Historic 2 in my '85 Honda CRX, black, still number 29. Who do I contact, or is this enough? Thanks, Don
- Car#: 58
Don,
Are you going to run the Falkins?
David
David
- Car#: 314
Did I miss the run order somewhere?
No.Arthur Grant wrote:Did I miss the run order somewhere?
Re: June Super Regional Registration Open-RUN ORDER ADDED
Will the run order be the same for both days?
Yes.Kevin Pao wrote:Will the run order be the same for both days?
- Car#: 591
I have question on Changing my sons kart # to 192. He has a co driver now. Is it to late to change numbers?
Last edited by Robert Baltazar on Wed Jun 13, 2012 8:59 pm, edited 1 time in total.
1991 turbo RX7 12.4 111.18 mph http://www.youtube.com/watch?v=WmeEuCbcNUg" onclick="window.open(this.href);return false;
Cal speedway 1.55
http://www.youtube.com/watch?v=3hhunwtiGLk" onclick="window.open(this.href);return false;
Cal speedway 1.55
No problem. Who's the co-driver?Robert Baltazar wrote:I have question on Changing my sons kart # to 192. He has a co driver now. Is it to late to change numbers?
- Car#: 591
The co driver is bejion yeoh...
Cal speedway 1.55
Cal speedway 1.55
I don't see Bejion as registered and reg is closed. Need Stephen or someone to contact me.Robert Baltazar wrote:The co driver is bejion yeoh...
- Car#: 591
Hey Rick, I guess KJ is talking with Stephen. I quess I'll find out what's going on later this afternoon.
Thanks
Thanks
Cal speedway 1.55
Cal speedway 1.55
- Ryan Young
- Car#: 510
Hey Rick,
I'm running Novice/DSK this weekend and just wanted to double check my run/work group. I'm thinking that I am with the DS group (running Heat 5/working Heat 2) - is that correct?
Thanks!
Thanks!
Ryan Young
Solo Noob
#510 RTA, 2011 Subaru WRX
Solo Noob
Since you're DSK, I'm pretty sure you'd be with RTA, but DS and RTA run/work the same group, so it's all good.Ryan Young wrote:Hey Rick,
Thanks!
Yes, you have been re-classed to RTA/DS for the event. You'll be put back in Novice for local 1 day results and points. This is true for all Novices in the event - you have been re-classed into the appropriate regular class, RT if you are on street tires, otherwise your normal base class.Kurt Rahn wrote:Since you're DSK, I'm pretty sure you'd be with RTA, but DS and RTA run/work the same group, so it's all good.Ryan Young wrote:Hey Rick,
Thanks!
- Ryan Young
- Car#: 510
Excellent, thanks guys! In that case, what magnets/class letters should I put on my car?
Ryan Young
Solo Noob
Solo Noob
- Car#: 237
Ryan Young wrote:Excellent, thanks guys! In that case, what magnets/class letters should I put on my car?
R T A
- Ryan Young
- Car#: 510
Got it - thanks again!
Ryan Young
Solo Noob
Solo Noob
- Car#: 237
Ryan Young wrote:Got it - thanks again!
Do you have a set??? Jay Woodruff make good numbers and letters, It is a little late probably for this event.
I have a extra set in red, isn't your #'s red you can borrow them for this weekend if need be.
Let me know so i can pack them .
