X-ray wheels for damage
Any recommendations on places in the LA area that can X-ray used wheels and control arms for cracks? And how much would that cost? Thanks.
- Anthony P.
Re: X-ray wheels for damage
Interesting. Usually it's not worth it vs buying new wheels.
- Christine Grice
- Car#: 17
X-ray is probably not the right tool for that job. Unless the part is thin or the crack is large enough to extend all the way through the part, the x-ray is just going to pick up all the metal behind any cracks that may exist and show you a solid part. Even a Doctor can't see a fine crack in a bone on x-ray. You'll probably need a dye penetrant test or some form of a electromagnetic inspection.
- Reed Gibson
- Current CSCC Overall Champion
Bust out the pink stuff!Christine Grice wrote:X-ray is probably not the right tool for that job. Unless the part is thin or the crack is large enough to extend all the way through the part, the x-ray is just going to pick up all the metal behind any cracks that may exist and show you a solid part. Even a Doctor can't see a fine crack in a bone on x-ray. You'll probably need a dye penetrant test or some form of a electromagnetic inspection.
