Harness Bar for Nissan 350z - $200
codea17
Post by codea17 »
This bar is an awesome solution to safely and securely mount harnesses in your 350z without the added weight of a full roll bar.
Designed and built by a professional mechanical engineer using CAD. Made from 1.75x0.125" D.O.M. steel tubing bent by a reputable mandrel bending shop. FEA simulations show that it can withstand at least a 40 g impact with driver and passenger weighing 200 lbs each. Total cost was around $400 for parts and bending.
Mounts at the upper stock seatbelt bolts and pre-drilled holes in the trunk designed for child safety seats. No drilling required!
Paint condition is 7/10 with a few nicks and slight discoloration where the harnesses mounted.
Located in Pasadena for pickup, or I can bring to the next event.
350z Roll Bar Support_Loads 1.png (68.27 KiB) Viewed 2477 times
350z Harness Bar von-Mises Stress 1.png (79.44 KiB) Viewed 2477 times
