LSD? To Have Or Not To Have
On our '99 Anniversary Edition CS Miata, we're suppose to have a LSD. Mechanical, not Viscous. Either works or it doesn't ... doesn't wear our like the weak viscous LSD in the rear of the WRX.
If we jack up one side, and the rear wheel turns freely, doesn't that mean we DON'T have a LSD?
It shouldn't matter which side we jack up, correct?
Apparently the rear dif was changed out at some point, and it seems like it was replaced with an open differential. :(
Gee ... maybe that's why we're having so much trouble getting power down coming out of corners? :?
Re: LSD? To Have Or Not To Have
Mako Koiwai wrote:On our '99 Anniversary Edition CS Miata, we're suppose to have a LSD. Mechanical, not Viscous. Either works or it doesn't ... doesn't wear our like the weak viscous LSD in the rear of the WRX.
The jack up and spin one tire trick does not work with a Torsen, which is what the 94'+ Miatas have. http://www.miata.net/garage/vlsd.html" onclick="window.open(this.href);return false;
The times I have driven that car I never had any reason to think it had an open diff.
Last edited by Jason Isley BS RX8 on Sun Nov 16, 2008 5:25 pm, edited 1 time in total.
That's a torsen diff in the 99 Miata's with LSD. Jacking both tires off the ground won't tell you anything because you have to have some load for it to lock at all.
err, yeah... What Isley said.....
So how does one check for the presence of a Torsen LSD?
Since we raised the car up to legal ride heights we've been having a lot of problems getting power down. One has to be very judicious with the throttle or else one gets a lot of inside rear tire spin on corner exit. We're actually lifting the inside rear tire completely off of the ground. That's unusual for a Miata isn't it?
Next need to check to see that we still have pressure in our front Penske reservoirs. Last time we checked a couple of months ago, they were fine. Replacing the front A arm tomorrow which suffered a sheared off sway bar attachment point at the last practice. 1.125" front sway bar; HD sway bar mounts.
The Side by Side shot with Tim's car, Ryan driving shows that are car were remarkable similar in cornering attitude. But Ryan did note that it was hard to get the power down on our Miata. He said that last year there was a time when Tim's car felt like that, but then Tim had the rear end "overhauled," and then it was "1,000 times better." We've replaced the bushings and had the Penske's rebuilt earlier in the year ... but the problem persists ... not sure what else we can do? We've softened the rebound in the rear quite a bit ... that helped ... and we're running the front as stiff as possible ... quarter off full stiff on rebound.
We're running 150 psi in front; 125 in the rear. Any other suggestions?
Karen vs Ryan.jpg (135.73 KiB) Viewed 12493 times
K, tail high.jpg (121.06 KiB) Viewed 12495 times
broken swaybar mount.jpg (151.27 KiB) Viewed 12492 times
Checking out Jason's link now ...
Mako Koiwai wrote:Checking out Jason's link now ...
The 10AE came with a Torsen. There are no external indications on any Miata differential that will tell you whether it's open or limited.
Isn't Tim's car the Sport model? Might have stiffer rear sway bar.
The Torsen action helps prevent a push in super tight corners. The one downside of the Torsen is that if one wheel is completely off the ground (zero traction) then the charactoristics of the Torsen will make it basically an open diff, both wheels have to have at least some traction for the unit to function properly.
:( ... we've got to get that inside rear tire touching the ground!
(Q)How do you identify Torsen's without dissasembly?
(A)The Torsen won't always turn both wheels when you turn the driveshaft, sometime if they are cold they will. One way is to take out the fill plug to see the Torsen gears which is hard to do because of the angle. Another way is to attempt to turn both half shafts in the same direction at the same time (tranny in neutral), can't be done with a Torsen. The foolproof way is to pull the stub axle on the type 1 or the drive axle on the type two. If you don't see a bar and can see directly thru the diff. it is a Torsen. If there is a bar, (spider gears) it's an open.
No bar=Torsen Torsen-Shaft.jpg (57 KB) Bar = open or RX-7 clutch type opendiffbar.jpg (39 KB)
Yes, soften the rear swaybar. Ended up disconnecting the rear bar in the supra and with a big front bar to solve that exact problem, got tired of v710 smoke at the exit of every corner. Got the Turbos spooled real good though.
Mako Koiwai wrote:Next need to check to see that we still have pressure in our front Penske reservoirs. Last time we checked a couple of months ago, they were fine. Replacing the front A arm tomorrow which suffered a sheared off sway bar attachment point at the last practice. 1.125" front sway bar; HD sway bar mounts.
All your problems sound like what you would get when you have a front bar issue. I have never heard of a Miata Torsen letting go on a stock car, and there is nothing to rebuild in there, no clutch pack.
Bob Beamesderfer wrote: Isn't Tim's car the Sport model? Might have stiffer rear sway bar.
A bigger rear bar would make it worse for Tim/Ryan.
Yeah, that makes more sense now that I think about it again.
A bigger rear bar wouldn't be legal in Stock.
Mako, you have to keep that rear wheel on the ground for the Torsen to work. Your options include stiffening the front bar and softening rear rebound damping. I'd start with the latter since you probably already replaced the stock front bar.
I agree. The RX8 had the exact same problem when my front bar came loose in San Diego.
Should we try increasing the pressure/damping beyond the 150 psi that we have in the front Penske reservoirs?
Increase the rear pressure also ... to help drive that inside wheel down?
So I guess it's OK in Stock to disconnect the rear bar ... you just can't change it out ... right?
Eric Clements
Post by Eric Clements »
[quote="Mako Koiwai"
So I guess it's OK in Stock to disconnect the rear bar ... you just can't change it out ... right?[/quote]
Only if the factory service manual says that disconnecting the rear bar is OK for normal street duty.
Yes, I think this is what's happening to us in the MX5 at El Toro on some of the harder turns.
Mike Simanyi wrote:A bigger rear bar wouldn't be legal in Stock.
Wasn't saying he should bet one. Just noting possible difference in 99 Sport vs. 10AE
Mako Koiwai wrote:Should we try increasing the pressure/damping beyond the 150 psi that we have in the front Penske reservoirs?
One adjustment at a time. Soften the rear rebound damping.
We had the rear rebound set to 5 turns off of full stiff on our Penske's at the last event ... after the front bar attachment point broke. Can't go much softer.
In the last few years there has twice been a LSD check for a class at Nationals ... where they had the competitors jack up one side of the car ... I believe, as opposed to front or rear. How we're they testing for an LSD doing that?
John Coffey
Car#: 250
Post by John Coffey »
Take off the rear cover and look inside. Spinning wheels to check for an LSD is foolish.
That's got to be the dumbest thing I've ever heard Solo2 tech do.
They have had us jack our cars up on one side and remove two tires but it had nothing to do with checking for an LSD. It was just so that the competitors/impound could get a better look at the suspensions. For example, missing bumpstops on a stock mini.
When they checked diffs in STS2 this year they were removing halfshafts and looking inside. Not turning wheels.
Not when it is done in a class with only open diffs. And this year they pulled an axle.
