Spring Install (Gap) Question
I installed the 8 inch, 2.25" 500/300lb springs into Karen's Miata yesterday. It looks like that when in full droop, the front shock assemble will have a good 1" gap between spring and it's upper retainer. Rear has only about a 1/4" gap at full droop.
Do we need to be concerned about this? Are we safe to run the Porsche AX on Sunday?
Would the front end ever get into full droop enough to warrant getting helper springs? We've also got the 1.125" RB sway bar in front.
The rear, with the oem springs, use to often get into full droop under hard cornering. We're hoping that now being stiffer and LOWERED ... Charlene will stop having her butt so high in the air!
Photo shows about three inches of gap while I was checking things out, before setting the ride heights. We're going to be at 12.75" in front, 13" in the rear.
Re: Spring Install (Gap) Question
Just don't do any dukes of hazard stunts on sunday and you should be fine, :lol:
Tom Denham
Car#: 237
Post by Tom Denham »
Can you add a Helper Spring?????
John Coffey
Car#: 250
Post by John Coffey »
Not a problem. Just make sure the springs seat properly every time you drop the car off the jack. If it concerns you, Hyperco and other sell helper springs for $20 to $35 each.
Jeff Wong
Car#: 146
Post by Jeff Wong »
Mako, is that already adjusted for a certain ride height? If not, the gap will change depending on how low or high you want it. I would think that the spring would come up a little more since you will be losing 3" of travel off the bat.
Jeff Wong
1994 Honda Civic- STS
ProParts USA
Like Us on Facebook
Here is the front gap at our desired ride heights of 12.75" ... at full droop. I don't believe we ever typically get to full droop in the front, especially now with the short stiffer springs, car lowered. Should be OK.
Karen Zaterman
Car#: 134
Post by Karen Zaterman »
The question is...
Sunday is coming very soon so it will be without the helper springs.
We've been talking it over & don't think it will be a problem but I would feel better with some additional SERIOUS input.
TIA, K
No, Mako -- you do NOT need to supercharge your new Miata! ...cuz now it's my turn to take it to the track :)
hmmmm... it is no longer "new" -- is it time to get faster?
Jeff Wong
Car#: 146
Post by Jeff Wong »
Mako Koiwai wrote:Here is the front gap at our desired ride heights of 12.75" ... at full droop. I don't believe we ever typically get to full droop in the front, especially now with the short stiffer springs, car lowered. Should be OK.
I'm assuming that the spring sits on the upper spring perch flat? You should be okay if it does. All the ST miatas on Koni yellows have the springs sitting on just the upper shock mount which isn't ideal, but it works, just make sure you don't over tighten the bushings.
This is a penske setup with our upper shock mount
EDIT: The picture below is not set to any ride height however it is common to have free play between the spring and upper perch depending on the extended length of the shock.
BTW: They are $150.00 for the PAIR if you want to be blinging :king:
Jeff Wong
ProParts USA
Like Us on Facebook
Is your sway bar attached?
Karen Zaterman wrote:The question is...
TIA, K
My input WAS serious. Supra has had more droop than spring for 3 years, just be careful when you set it down.
John Coffey wrote:Not a problem. Just make sure the springs seat properly every time you drop the car off the jack. If it concerns you, Hyperco and other sell helper springs for $20 to $35 each.
I agree, the Escort had WAY more droop travel than spring travel (@600#/in, it only compressed the spring about an inch) without helper springs and it was never an issue except for, as John noted, making sure it was properly seated when lowering. Looks like your bumpstop will virtually guarantee that, anyways. In turns, your sway bar will probably keep that shock from extending beyond the spring.
Reijo Silvennoinen
Car#: 60
Post by Reijo Silvennoinen »
Make sure you take up the space otherwise your car height will be too high. :lol:
Yeah, on Bill's Miata we had to ensure the front springs were "in place" everytime we raised/lowered the car.
It's just a fact of life with short springs.
Reijo
Reijo
BS - CASOC
Karen Zaterman
Car#: 134
Thank you all!
SERIOUSLY! You guys rock :thumbup:
Now, Aaron, how does 2 feet from trees, 100 MPH, sideways sound?
Car was good last Sunday at the Porsche club event... looking forward to testing more next Saturday. You won't see her acting like a slut anymore with her tail in the air. :cry:
...and in answer to Steve, rear sway bar was disconnected on Sunday.
Last edited by Karen Zaterman on Tue Feb 24, 2009 6:53 am, edited 4 times in total.
Karen Zaterman
Car#: 134
Jeff Wong wrote:This is a penske setup with our upper shock mount
Tempting, but cutting back on expenditure for awhile. These are sweet looking tho'. I'll post it on Charlene's Facebook account as her 1st wish list item. ;)
Karen Zaterman wrote: Now, Aaron, how does 2 feet from trees, 100 MPH, sideways sound?
Sounds awesome! Where do i sign up?!
:lol: Top 100 NASIOC inspired memes.
Awesome if it refers to this video:
http://www.youtube.com/watch?v=KYFxSilcqgs" onclick="window.open(this.href);return false;
maybe Mr. Motonishi can tell us what that feels like?
... and Andi M.
Jeff ... is that the Penske SLOTTED upper spring retainer? Is there any rubber bushing material under the top hat?
The car was much flatter and easier to drive. We were only on real and old street tires. This weekend we'll have our race Dunlop SS's on ... which will of course produce a bit more lean. Car was a little loose at first. We lowered the rear a good 1/8th inch, soften the rebound another turn to erase that. Later we took the front bump up from 2 to 4 out of 6, and the felt a bit better, but wasn't faster. We're down to around 12.5" all around.
NO issues with the spring gap, which of course is disappearing as we continue to lower the car. 6" or 7" 2.5" springs had been recommended. We went with 8" springs but 2.25" IO.
Coming out of the slowest corner where we were cranked over the most. In the past we would be on the verge of lifting our inside rear tire.
Mako Koiwai wrote:We were only on real and old street tires. This weekend we'll have our race Dunlop SS's on ... which will of course produce a bit more lean. Car was a little loose at first. We lowered the rear a good 1/8th inch, soften the rebound another turn to erase that. Later we took the front bump up from 2 to 4 out of 6, and the felt a bit better, but wasn't faster. We're down to around 12.5" all around.
making setup changes on crappy tires is a good way to thoroughly screw stuff up. tear that page of setup changes right out of your log book. start over again when you put the real tires on.
Marshall Grice wrote: making setup changes on crappy tires is a good way to thoroughly screw stuff up. tear that page of setup changes right out of your log book. start over again when you put the real tires on.
Amen.
I'll pass that on to the car owner ... she who signs the checks
