140 treadwear street tires for 14" rims.
- Michael Smith
- Car#: 21
I have some Falken Azenis (200 treadwear) for the Civic but was wondering if there is a better street tire available.
The Azenis are also taller.
Stock 185-60-14
Azenis 195-60-14
Michael
Stock 185-60-14
Azenis 195-60-14
Michael
Re: 140 treadwear street tires for 14" rims.
Tire size calculator: http://www.miata.net/garage/tirecalc.html
What class are you running ... almost no 14" high performance tires out there ... can you go to a 15" wheel?
- Michael Smith
- Car#: 21
HS NOV but looking to run SK2 after. I can't change rim size.
Michael.
Michael.
Competitive 14" street tires can be counted on the hand of a blind punch-press operator. The Toyo T1R comes in a 195/55-14 and a 195/45-14. The 195/45 could be a gearing blessing or curse depending on the course, but it is a pound lighter and 1.5 inches smaller in diameter than the 195/55. Wear can be an issue. Despite the 200 treadwear rating, it's a soft compound.Michael Smith wrote:I have some Falken Azenis (200 treadwear) for the Civic but was wondering if there is a better street tire available.
Stock 185-60-14
Azenis 195-60-14
Michael
But on a light car wear shouldn't be toooo bad
Ask Steve Ekstrand about that.Mako Koiwai wrote:But on a light car wear shouldn't be toooo bad
I said Light Weight !!! ;)
I thought you meant the car.Mako Koiwai wrote:I said Light Weight !!! ;)
Total Weight !
- Steve Coe
- Car#: 75
The Falken RT615's are the only way to go for a 14" 140 tread wear tire.
I love to Toyo T1R's, but they won't hold a candle to the 615's on an autocross course. I have the 195/55x14's on my STS(2) Miata for street tires. Great for the street but....
BTW the Toyo T1R's have a UTQG of 280 not 200.
- Michael Smith
- Car#: 21
What about the Bridgestone Potenza RE92? It has a treadwear of 160 and comes in 185/60/14.
Is the narrow tire worth the softer rubber?
The RT615 seems like the best choice economically considering the are only $270/set locally.
Never take the UTOQ as gospel.
The 92 use to be the oem tire for Suby WRX's ... it's a HORRIBLE tire !!!
I don't think any tire is close to the Flaken in 14".
The only other tire I'd investigate would be the Hankook Ventus RS-2 Z212 but probably only if the Flaken's were backordered.
Yeah, 280 tread wear. In someone's geisha dreams. I put a durometer on them and the reading was in the R comp range.Steve Coe wrote:The Falken RT615's are the only way to go for a 14" 140 tread wear tire.
What tire was Motonishi running at the Pro? What tire was on places 2 through 10?
You'd take the Falken over the Toyo? You are still running the Toyo, right?Steve Ekstrand wrote:I don't think any tire is close to the Flaken in 14".
wouldn't be surprised if Toyo came out with a 14" series R1R's if SK classes become nationalBob Beamesderfer wrote:You'd take the Falken over the Toyo? You are still running the Toyo, right?Steve Ekstrand wrote:I don't think any tire is close to the Flaken in 14".
They already have two 14-inch R1R sizes, 195/55-14 and 195/45-14.Jonathan Lugod wrote:wouldn't be surprised if Toyo came out with a 14" series R1R's if SK classes become nationalBob Beamesderfer wrote:You'd take the Falken over the Toyo? You are still running the Toyo, right?Steve Ekstrand wrote:I don't think any tire is close to the Flaken in 14".
Guys..... You are confusing the Toyo T1R and the Toyo R1R.
VERY DIFFERENT TIRES!!!!!
t1R has two 14" sizes and a very real 280 UTOQ
R1R has NO 14" sizes and a very soft but not real tacky 140 UTOQ
OK, yes, T1R not R1R. Still, the durometer numbers on the T1Rs you had at the PSCC practice were way softer than a 280 rating would suggest.Steve Ekstrand wrote:Guys..... You are confusing the Toyo T1R and the Toyo R1R.
I've never used a T1R.
I run Toyo R1R's with a 140 treadwear rating. And yes they are soft, squishy and squirmy.
Damn. I is confused.Steve Ekstrand wrote:I've never used a T1R.
Well, Bob, at least you know your durometer is working properly.Bob Beamesderfer wrote:Damn. I is confused.Steve Ekstrand wrote:I've never used a T1R.
- Michael Smith
- Car#: 21
Re: Local KUMHO dealer?
I'll have to look at my options at the end of the season.
R-Comps until then.
Is there a local Kumho dealer that has better prices than Tire Rack?
R-Comps until then.
Don't know your definition of "local". Talk to Larry at Americas Tire in Ontario Mills. For years he has matched Tireracks price, w/ no shipping fees on Kumhos. In the past, deals have been available for mounting IF they are true race tires (not street, or street/race tires).
Craig
Craig
