Brake Pads for CS Miata ?
Should we have something "stronger" then Hawk HP+'s up front with Karen's CS Miata running 225 710's? Tim says No.
Re: Brake Pads for CS Miata ?
If her car has ABS use the HP+, if she does not use stock.Mako Koiwai wrote:Should we have something "stronger" then Hawk HP+'s up front with Karen's CS Miata running 225 710's? Tim says No.
Yes, ABS and HP+'s ordered.
What's this about using different pads front/rear to change bias. Does that really matter with ABS?
Porterfield R4S. Tim Aro really liked them in my non-ABS car.
Yeah, but we have ABS ...
So what? It's still a very good compound and easy to modulate. Unless you plan on engaging the ABS every time you step on the pedal it's how the pad behaves out of the ABS that matters.Mako Koiwai wrote:Yeah, but we have ABS ...
Last edited by Bob Beamesderfer on Sat Jun 21, 2008 9:25 am, edited 1 time in total.
OK, but the HP+'s are already ordered and I need to convince Karen I did the right thing when she reads this! ;)
Luckily Isley has a LOT of credibility as THE Late Brake'r.
We had Hawk Blacks on up until now, in front, HP+'s in back ...
So now try the opposite of that.Mako Koiwai wrote:We had Hawk Blacks on up until now, in front, HP+'s in back ...
- Michael Palero
- Car#: 18
Mako's on a roll... switching springs front to back and everything :ibrightdea:Jason Isley BS RX8 wrote:So now try the opposite of that.Mako Koiwai wrote:We had Hawk Blacks on up until now, in front, HP+'s in back ...
and then there's my audi... it just rolls. =)
UH, that ain't legal.Michael Palero wrote:Mako's on a roll... switching springs front to back and everything :ibrightdea:Jason Isley BS RX8 wrote:So now try the opposite of that.Mako Koiwai wrote:We had Hawk Blacks on up until now, in front, HP+'s in back ...
Wasn't my fault ... I was just following the oem Bilsteins ... which some else had assembled BACKWARDS!!!
Struts are off for the rebuild ... with exact measurements from MazdaSpeed on which length springs we should be using!
