July FT
July FT
http://scca.com/documents/Fastrack/09/0 ... k-july.pdf" onclick="window.open(this.href);return false;
Giovanni Jaramillo
Re: July FT
Here's JUST the Solo portion
and boy was the Solo SEB busy this month! Took me a few minutes to read through all that. Hey Robert, looks like the Noble is geared for XP for 2010. Not sure if you were for or against that.
Gary Thomason
Re: July FT
Anybody we know got a spare Audi R8 laying around??Jason Isley BS RX8 wrote:http://scca.com/documents/Fastrack/09/0 ... k-july.pdf
GT
- Robert Puertas
- Car#: 44
Re: July FT
FOR!Giovanni Jaramillo wrote:Hey Robert, looks like the Noble is geared for XP for 2010. Not sure if you were for or against that.
Yes, it's out for member comment with another change. Great.
Maybe if they keep futzing with the wording long enough, people will stop bothering to write in and they can pretend to kill it with a clear conscience.
David Barrish
- Car#: 58
Re: July FT
Doug,
They want your car to go away, welcome back to Historic!
David Barrish
David Barrish
- Doug Teulie
- Car#: 99
Re: July FT
Thanks for the welcome back to HIST (very tempting offer)David Barrish wrote:Doug,
David Barrish
They want my red 1980 Scirocco (built to the 2000-2004 line rules) to go away but the silver 1976 Scirocco A1 is built to the 2005-2010 FSP line Rules. That is why I am driving the silver car now. The silver car was built when the red car became obsolete in 2005 due to line rule changes. They did not delete the old line when they added the new line. I did not want to miss any events as I was making the changes so I built up my parts car to the new rules. Now I am modifying the red car so it will be up to date (but should just leave it alone).The 1980 (in the old trim) is still covered under the 2005-2010 FSP Rule. When I built the 1980 I was restricted from using some parts and removing the center console. The difference is not that great. The sad part is that neither car is competitive with the cars that have twice the horsepower in the class.
Doug T
Re: July FT
Hey, and while you're writing in, throw in some support for the removal of the 100lb/200lb weight penalty in prepared for running larger than 16" wheels.Robert Puertas wrote:FOR!Giovanni Jaramillo wrote:Hey Robert, looks like the Noble is geared for XP for 2010. Not sure if you were for or against that.
Re: July FT
I want to know what the STR rules are going to be!
Re: July FT
Isn't the "sunset rule" just for stock class? Is SP affected too?David Barrish wrote:Doug,
David Barrish
Jason Uyeda
Re: July FT
STOCK ONLY!!!Sebastian Rios wrote:Isn't the "sunset rule" just for stock class? Is SP affected too?David Barrish wrote:Doug,
David Barrish
ITEM 7) Add new second paragraph to 13.0 as follows:
“A car will remain eligible for Divisional, National Tour, and National Championship events through the end of the 30th calendar
year after the manufacturer-designated model year of the car.”
Rad_ Delgado_
- Car#: 512
Re: July FT
Super !!! Audi R8 in Super Stock. Nice looking car, depreciating as fast as GM stocks, AWD, V8 and available manual transmission. All the camber you need, as it uses spacers on the wishbones, the 60 lbs exhaust can be removed, and lightweight wheels and sway bars are available.
Re: July FT
Dump that Fiat and buy a winner.Rad D__ wrote:Super !!! Audi R8 in Super Stock. Nice looking car, depreciating as fast as GM stocks, AWD, V8 and available manual transmission. All the camber you need, as it uses spacers on the wishbones, the 60 lbs exhaust can be removed, and lightweight wheels and sway bars are available.
Re: July FT
According to whom?Rad D__ wrote: Nice looking car, depreciating as fast as GM stocks, AWD, V8 and available manual transmission.
Rad_ Delgado_
- Car#: 512
Re: July FT
According to me. Not longer than 6 months ago it was impossible to get the hands on one for less than $150k, they're in the low 100s right now with a few ones popping once in a while in the 90s. With the incoming Cabrio and V10, I would expect them to be in the high 80s quite soon, similar market price as the 997 GT3.Bob Beamesderfer wrote:According to whom?Rad D__ wrote: Nice looking car, depreciating as fast as GM stocks, AWD, V8 and available manual transmission.
Super Stock with R8, Viper, Elise/Exige, GT3, Cayman looks so nice. Unfortunately, there is still a high number of plastic Barbie cars in the class in their way to extintion.
No need to dump it. Winner already here, lighter, shorter, narrower, and pretty soon more powerful.Jason Isley BS RX8 wrote: Dump that Fiat and buy a winner.
Re: July FT
Yeah ... handles much better ... much flatter }:)
- Rad's.jpg (87.79 KiB) Viewed 12192 times
Re: July FT
... really it did ... TTD ! ... even though it had grown men running in fear ...
- Rad's2.jpg (94.41 KiB) Viewed 12190 times
Re: July FT
Where's the video from that Run ?
- Jamie Lessie
Re: July FT
Did you drive that thing Mako
Re: July FT
Hey, just because it's spinning doesn't mean I'm (trying to) driving it!
That was Chris G, Rad's co-driver ... trying to up the TTD, on his way to the PCA X Class win last Sunday:
- ChrisGrivas.jpg (49.12 KiB) Viewed 12146 times
Rad_ Delgado_
- Car#: 512
Re: July FT
My timed runs, #1 on cold tires, #3 not in video (forgot to hit Record button)
http://www.vimeo.com/5330028
Chris timed runs, #1 on cold brain
http://www.vimeo.com/5329871
Re: July FT
I don't where you're looking, but Cars.com shows 38 R8s nationwide; cheapest is $104,900.Rad D__ wrote:According to me. Not longer than 6 months ago it was impossible to get the hands on one for less than $150k, they're in the low 100s right now with a few ones popping once in a while in the 90s. With the incoming Cabrio and V10, I would expect them to be in the high 80s quite soon, similar market price as the 997 GT3.Bob Beamesderfer wrote:According to whom?Rad D__ wrote: Nice looking car, depreciating as fast as GM stocks, AWD, V8 and available manual transmission.
The Cabrio isn't going to effect the coupe's price; two different buyers. Personally, I wouldn't want the Cab; even though I like open cars Audi convertibles are way heavier than the hardtops.
- Tadd Ekstrand
- Car#: 152
Re: July FT
Gary Thomason wrote:Anybody we know got a spare Audi R8 laying around??Jason Isley BS RX8 wrote:http://scca.com/documents/Fastrack/09/0 ... k-july.pdf
My girlfriends neighbor has one and it doesn't seem to get driven much since he got the ZR1
Tadd Ekstrand
STS 91 Honduh Civie Si Iamokwithmysexuality blue
New avatar courtesy of Mako Koiwai.
Speed never killed anyone; suddenly becoming stationary... that's what gets you
Re: July FT
Not too surprising. If he wants someone to keep it exercised I'll do that for free.Tadd Ekstrand wrote:Gary Thomason wrote:Anybody we know got a spare Audi R8 laying around??Jason Isley BS RX8 wrote:http://scca.com/documents/Fastrack/09/0 ... k-july.pdf
Gary Thomason
Re: July FT
Great!Rad D__ wrote:Super !!! Audi R8 in Super Stock. Nice looking car, depreciating as fast as GM stocks, AWD, V8 and available manual transmission. All the camber you need, as it uses spacers on the wishbones, the 60 lbs exhaust can be removed, and lightweight wheels and sway bars are available.
I hope you and the 3-4 other guys in the country that can afford these cars and like to slum at an autox enjoy SS }:)
GT
- Robert Puertas
- Car#: 44
Re: July FT
So is the Tesla a complete non-starter in SS?
My pessimistic mind was wondering if the R8 was a way of hiding the Tesla's classification.
Kinda like what happened to Farah when Michael died...
