I am putting Koni yellows on the 95 M3. The original shocks have a bump stop "built in" at the top of the piston shaft. The Koni's I got have nothing. Do I need to buy/fab some bump stops to limit suspension travel & prevent bottoming or tire hitting something?
Thanks.
BMW rear shock bump stops
Re: BMW rear shock bump stops
Koni generally supplies bump stops with their shocks. If not, you can get them from the place you got the the shocks.
John Coffey wrote:Koni generally supplies bump stops with their shocks. If not, you can get them from the place you got the the shocks.
Thanks John,
These are used & the Koni bump stops must have got lost along the way. I reused the oem's & they will do for now.
