I'm looking for 2x10mm and 2x5mm spacers for my miata but I don't know where to get them from.
Do you have any place to suggest?
Btw the issue is that my rear 275 A6 tires (on 949 15x9 wheels) are rubbing at the top inside the fender wells and also my front ones are rubbing on the sway bar and on the shock top mount.
At the front I'm already using 5mm spacers (Donated by Bill S - Thanks Bill
So the plan is to use the 10mm at the front and try the 5mm at the rear.
Thanks
Chris
