CarMax didn't say anything about my WRX's two accidents. One was a light re-ender, the other one was a mystery since I bought the car new ... it supposedly only had 7 miles on it. Only when I sold the car did conclusive evidence of it being in another accident come out. A potential buyer pointed out that the left front fender had been repainted, because he could feel the sharp edge where the new paint stopped under the hood (the other fenders paint line WAS smoother), and then THE buyer pointed out that the paint didn't quite match the rest of the car. I had owned the car for something like 40K and had never noticed that, but in the particular light in his driveway, for the first time, I DID notice that that fender was a warmer silver then the rest of the car !?!?!
When I started to race the WRX it was always a problem getting enough camber on the left side as compare to the right front. Later I found the Datum points for the car, and the front strut towers were further away from each then oem by something like 4 mm. (Ray E's WRX had been hit in the front side and his towers were closer together then oem, giving him extra camber.) There was also that good size chip of paint that popped off of one of the strut towers ... before I started to AX it. The car had obviously been in an accident when it was BRAND new, before being sold to me by the dealer!
So even though it was supposedly expertly repaired it finally came out. Luckily the buyer didn't press the point.
My Previa got rear ended very hard in a hit and run while parked. It took many weeks to get the high end body shop to get permission to replace all of the suspension and bushings that had been damaged. Since then things have cropped up that were very likely related to that hard rear/side rear ender. Like one of the CATS coming loose inside of it's canister. The Problem, on the Previa, BOTH CATS are in one piece of exhaust tubing, ie. the replacement part is over a $1,000!
Can you imagine the impact it took to bend this steel wheel?
