Street tires. Dunlop's
I could use more grip in the rear.
wheels and tires currently are:
Front --- 18x8 245/40/18 should I go 255/35/18 ?
Rear ---- 18x9 265/35/18 should I go 275/35/18 ?
I know these wider tires will fit with minor rubbing in the front only.
camber maxed out in front:
front -1.5 degrees
rear -1.8 degrees but I could get a lot more
Im figuring for R's (Hoosiers) because of a stiffer side wall that going wider would be beneficial. But let me know if Im wrong.
thanks for the help
